Old 11-13-2003, 01:30 AM
Stus99GT Stus99GT is offline
Floating Gas Gauge
My girlfriend has a 1997 Lumina. The gas gauge seems to be pretty messed up. When the car is almost low on fuel the gauge will show half a tank left, or will show that the car is full. Could this just be the gauge or could it be a problem with a sensor? Thanks for any help!
Old 12-08-2003, 11:03 AM
gwsample gwsample is offline
Question me too!
I too have a 97 Lumina with the same problem... if you get any ideas, let me know.
Old 12-08-2003, 03:15 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: me too!
Could be one of two things. Either the sensor in the tank...or the gauge cluster. GM's electronics aren't known for their reliability.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 12-10-2003, 03:59 PM
RABarrett RABarrett is offline
Re: Floating Gas Gauge
Do you refer to full, or past full? Past full indicates that the sender is not connected to the indicator. This sounds to me like a sender issue. Try locating the sender wire, and do a resistance reading. Disconnecting the connector should send the indicator past full, shorting the wire to ground should indicate empty. If necessary, you may need to do a resistance reading on the sender, but this will require removal of the sender to check for a smooth resistance change as the sender moves. Ray
Old 03-24-2005, 08:50 AM
lrastsr01 lrastsr01 is offline
Re: me too!
Have just atarted having this problem and joined forum looking for answer if I find solution will get back to you
floating gas gadge slimnottygirl Venture 5 06-25-2006 05:46 PM
temp gauge and gas gauge shaolyn '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-18-2005 03:59 PM
DIC gas gauge,speedometer, temp gauges not working hotep Aurora 7 05-09-2005 11:26 AM
Gas gauge stuck & no amp gauge makailaann Ram Pickup | Ram SRT10 1 05-09-2005 09:35 AM
gas gauge is stuck half way with full tank of gas jerom 3 Series 3 07-14-2003 08:50 PM
