Old 06-18-2005, 03:34 AM
shaolyn shaolyn is offline
Send a message via AIM to shaolyn
Question temp gauge and gas gauge
im having trouble with my gauges... first off i drive a 88 dx hatchie.. well i took the cluster gauge from my bro crx si... i install the cluster and the rev works fine and the speedometer is okay but my temp keeps rising all the way to hot everytime i fire the car up... but my phantom temp gauge says that it is only at 100 degrees f. then my gas doesnt seem to be working either... so confusing... everything is plugged in i dont kno what the deal is with the temp and the gas gauge... any help will be appreciated..
Old 06-18-2005, 09:46 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: temp gauge and gas gauge
your other cluster still works fine right? id say the gauges are bad, you should try swapping out the temp/gas cluster section. then again, if you had another Si cluster to take that part out, you could just stick it in.
are the years the same between the clusters? because the wiring is different on 88-89 and 90-91
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-18-2005, 02:26 PM
yea the years are right its an 88 si cluster going into my 88 civic dx.. are you saying to get diff. needles or that whole gas and temp section swapped out..?
90 nissan 240sx
Basically Bonestock...
Drop In K&N Filter...
243,000 miles on the odometer!!!
Still Runnin Haha
17' Racinghart CR5 Black Polished Lip
Old 06-18-2005, 03:59 PM
EF You's Avatar
EF Life Giver
that whole section. but then again, if you swap that whole section, might as well swap a whole cluster.
