Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-22-2005, 12:43 PM
hotep hotep is offline
Question DIC gas gauge,speedometer, temp gauges not working
I don't know were to start. My 96 aurora (my baby) I have replaced the alternator, egr valve, water pump, radiator. I have invested alot of money in this car. Now the gas gauge, speedometer, and temp gauge, along with the dic have all stoped working. I found a penny in the cigarette lighter (I thinnk thats what triggered the malfunction). I have checked all the fuses (drivers side door, under the hood, and under the back seat) none were blown. The doors no longer auto lock when i put the car in drive hell they don't even work. the radio also cuts off as soon as the car is turned off I dont know what it could be worng any help or suggestions are much appreciated.
Old 03-22-2005, 01:32 PM
chris_fit chris_fit is offline
Send a message via AIM to chris_fit
Re: DIC gas gauge,speedometer, temp gauges not working
Sounds like a simple grounding issue somewhere. I would check make sure the grounds in those areas are ok, Where they are I have no idea.
Old 03-22-2005, 08:19 PM
Isnibs's Avatar
Isnibs Isnibs is offline
Wot chris_fit said.
and
did you check to see if there is a relay that may be at fault.
After the penny incident did everything go poof together or individually.
1996 Aurora Black / grey
Old 03-23-2005, 07:57 AM
After the penny thing everything went poof all together, heat controls, DIC, Gas gauge, speedometer, Temp gauge. Not to sound stupid but what is a relay and were is it located?
Old 03-23-2005, 08:07 AM
Re: Re: DIC gas gauge,speedometer, temp gauges not working
Triple check the fuses.
Old 03-23-2005, 08:09 AM
checked every fuse in the car 4 times
Old 03-23-2005, 07:01 PM
Isnibs's Avatar
The relays are in with the fuses. if you dont have a manual try this
link it may give you some idea.
http://www.howardm.net/dred98/underhood.php
Thanks to Dred98
Old 05-09-2005, 10:26 AM
Aurora95 Aurora95 is offline
it is one of your fuses. how did you check your fuses. did you take everyone out and look at them or did you used a test light?
you should use a test light because some fuses can be blown but the metel inside might not look broken. when you check the fuses look carefully at the conors of the fuse. but one of the fuses are blown thats why you have that problem. it's not a relay
Thanks to Dred98[/quote]
