Old 11-12-2003, 02:37 AM
blueburbboober blueburbboober is offline
I'm gonna go crazy, does anyone have any ideas?
I'm gonna drive my burb off a cliff...
I've never been so stumped in my life. The dealer wont look at my burb, and the autostores gave up.
(95 GMC suburban, 350 engine, 4x4, 1/2 ton)
I'm having a low horsepower problem, and its only when its under a load, like when i accelerate on the freeway, onto the freeway, and climb grades.
Ive replaced:
plugs
cap
rotor
plugwires
exhaust with 70 series flowmaster and walker CATALYTIC convertor with dual stainless tips
inline fuel filter
O2 sensor
throttle position sensor
fuel PUMP and sock
air filter
had the electronic part of the distributor tested.
i compared the spray of my injectors to that of a working truck, looked the same....
I'll mail the first person on this thread to give me the right answer a 20 dollar bill. I'm dead serious. If noone can figure it out, its gonna be up for sale, cause im sick of it.
thanks for any help i get
-Rob
ps. i have no check engine light on, or anything of the sort. hence why the dealer wont look at it.
No more burb for me!!
2005 Jeep Wrangler. Blue, 4.0L
2004 Jeep Wrangler Unlimited. Bright green, 4.0L. No mods yet on either!
Old 11-12-2003, 09:03 PM
jamesrr jamesrr is offline
Re: I'm gonna go crazy, does anyone have any ideas?
Rob
I feel your pain, My "burb" has also stumped me.(See 88 bucking)
Your problem seems to be in need of basic rethinking. I'm not one to just throw parts in and see what happens next.
Look, one thing burbs have a reputation for is power
and if yours has low hp begin at the basics
air in fuel in exaust out timing/compression
when you went to aftermarket exaust did you change the cat?? a exaust restriction could be the problem.
If it was me I would disconnect and give it a test run.
How many miles?? I'm wondering about compression.
compression gauges are cheap or can be "borrowed from auto parts stores"
Did you actually test the fuel pressure?
This is also another gauge that can be borrowed
not purchased.
Good luck. let us know
Old 11-13-2003, 09:13 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: I'm gonna go crazy, does anyone have any ideas?
First thing is to check the timing..base and advance
Maybe advancing the timing a few degrees may solve your problem.
Check fuel pressure..should be about 9-14 psi...I like to see at least 12.
Checking compression and exhaust back pressure would be next.
If I get it right...send the 20 to a good charity
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-20-2003, 09:14 PM
99ssconv 99ssconv is offline
what about restricted or low vacuum to the map sensor, maybe the throttle body passages are clogged, just a thought.
Old 11-24-2003, 09:23 PM
stubbornmike stubbornmike is offline
Ive replaced:
plugs
cap
rotor
plugwires
inline fuel filter
O2 sensor
fuel PUMP and sock
air filter
-Rob
The problem to your engine.
You HAVE a lower intake manifold leak.. COULD BE air or water maybe both.. it robbs you of power during take off... the lower intake manifold its made of thin rubber it cracks over time allowing air or raditor fluid in over time
----mike
Old 12-02-2003, 09:40 AM
dirty dan dirty dan is offline
I'm fighting a similar problem on '89 burb. Try advancing your timing by maybe 8-10 degrees(must disconnect EST wire when setting timing and re-connect when done). Should provide more power on highway, but will probably cause a poor idle. Disconnecting O2 sensor puts ECM into open loop and smoothed up the idle on mine. Let me know what happens. I have not been able to isolate the problem. I've gone as far as placing my ECM & PROM into a similar burb and it ran like a dream.
Old 12-02-2003, 10:16 AM
Does anyone have any advise on a starting problems I am haveing with my 97 Blazer S10 Lovemy97Blazer Blazer 5 01-31-2006 10:05 PM
ANyone have any ideas to bring the shine back? 93nismo240 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 03-30-2004 08:58 AM
Big problems with the brand new Passat. . .anyone have any ideas? kraynek Passat 1 12-29-2003 10:46 PM
OT: Anyone have any idea how much Honda Tech's make? Killa_CRX '88 - '91 Civic | CRX | Wagon | Shuttlee 10 11-28-2002 07:08 AM
Does anyone have any freggin idea highbrid Car Audio 5 12-18-2001 07:10 PM
