Old 01-30-2006, 12:35 PM
Lovemy97Blazer Lovemy97Blazer is offline
Does anyone have any advise on a starting problems I am haveing with my 97 Blazer S10
Hi,
My 97 Blazer is exhibiting a frustrating pattern. If I don't use it for two or more days, it will not start.
Especially if its wet or damp out, the car will turn over and sound like its going to start but most time doesn't. The battery drains down and I have to jump it. Once I hook it up to my other car, it will kick over, sputter and start every time. It sounds like not all the cylinders are firing until it gets full power from another car. During the start-up process, I can hear it misfiring and then it slowly starts to sound better and then sounds and runs great.
It is like moisture is getting into the electrical system somewhere. This is a high mile Blazer and the check engine like goes on and off but mostly stays on. I have not brought it in yet for service. I was going to change plugs and wires first.
Does anybody have any thoughts??? Thank you!
Old 01-30-2006, 01:01 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Does anyone have any advise on a starting problems I am haveing with my 97 Blazer
Originally Posted by Lovemy97Blazer
Hi,
First of all, Welcome to the board. What you have described can be a number of different things that is causing your trouble. You’ll need to first get the error codes that are keeping your service light on. Let us know what they are and we can go from there.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 01-30-2006, 01:10 PM
scholzee scholzee is offline
Re: Does anyone have any advise on a starting problems I am haveing with my 97 Blazer S10
Usually when problems happen in the damp it is distrubor cap or wires. Since its high mileage and if you do not know when last changed, I would do cap, & rotor, plugs and wires. The middle plug on drivers side is tough search this forum and it will show you how to remove steering shaft or just leave that one for now until you get better starting and do that one another time.If it does not help you need to verify proper fuel pressure, there is a shrader valve back near the distributor which a guage hooks up to and I believe the spec is 62-66 psi any lower and injectors do not fire properly. The fuel pump is very sensitive to battery voltage, excessive cranking causes low voltage low pressure, jumping adds another vehicles battery increases voltage and can increase fuel pressure. Also search for the ignition key switch that many 97's had problems with I know they can cuse a bunch of problems not sure if starting is one. Good Luck
Old 01-30-2006, 08:32 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
I second the distributor cap. Remove the cap and look for moisture inside of the cap or in the distributor, also check for cracks and holes in the cap. If you see any moisture, get Mama's electric blow dryer and an extension cord and "Dry" the disributor. If you do have moisture inside the cap replace it. It is very simple to replace the cap, just remove one wire at a time.
Old 01-31-2006, 06:46 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Originally Posted by Rick Norwood
...dryer and an extension cord and "Dry" the disributor. If you do have moisture inside the cap replace it. It is very simple to replace the cap, just remove one wire at a time.
I had a few of my ribs disributored once, very painful...
Just kidding, I agree.
(removing the wires is easy, getting them back in the correct position is the ultimate goal)
As Rick said and I'll expound, replace the wires 1 at a time with the new cap next to the old cap; remove from old, insert in new.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 01-31-2006, 10:05 PM
XPC2004's Avatar
XPC2004 XPC2004 is offline
Send a message via MSN to XPC2004 Send a message via Yahoo to XPC2004
Hi,
Especially if its wet or damp out, the car will turn over and sound like its going to start but most time doesn't. The battery drains down and I have to jump it. Once I hook it up to my other car, it will kick over, sputter and start every time. It sounds like not all the cylinders are firing until it gets full power from another car. During the start-up process, I can hear it misfiring and then it slowly starts to sound better and then sounds and runs great....
Mine did that, finally quit, replaced the fuelpump, and purrss everytime now.
(did a whole bunch of tests first to trace the problem) Like others post, do some tests, voltage fuel psi, etc. (didn't replace cap, rotors, plugs, or anything, just eliminated one thing ata time) Hooked up the fuel pump test lien and it didn't go, the relay was fine, and the engien started if there was fuel, jsut dided because there was no fuel gettign to the engine.
It's fun figuring out your woes... this is the best palce for awesoem support and answers.
