Old 11-11-2003, 08:29 PM
balln69 balln69 is offline
Send a message via AIM to balln69
B16 or ZC???
Sup all, im looking to do a swapp soon, and i was wondering which motor has a higher potential, the zc or b16a1 vtec.??? whats the H/p of each, and which would be better for turbo???.. ive herd that zc is like 134hp and b16 is 157-160 hp.. is this right? which would be better for a CRX and which is easier to swapp and stuff
a lil help plz
91 Crx Dx
{[Pensacola]} Crx Representing [{P'Cola}]
({[-Later]})
Drop a Gear
and Dissapear
Old 11-11-2003, 08:43 PM
travagliante's Avatar
travagliante travagliante is offline
Re: B16 or ZC???
Ok im assuming you mean the DOHC ZC swap. Is the easiest. It is bolt in. You can also use your CRX transmission. If you have dpfi you need to wire it for mpfi. This by far is the easiest performance swap.It has 138hp. and i believe 108lbs tq. THe b16a which i think has the most tuning potential is 160hp. and 111tq. The b16a is oppiste of the zc bar far because it is a semi complicated swap. You need mounts linkage, rewire regardless of dpfi or mpfi, and a few other things that will give you a headache. But by far you will appreciate the b16s power. If you need moe tq. I wwould sugguest a ls swap or b18.
But if you use the zcs tranny u need shiftlinkage.
Its more a personaly preferance.
What do you need the power for??
A green light and go race or
a long haul highway race going 100+mpg.
I never get to real high rpms in 5th so i want more accelerations so id go with a b18. But its all about whats cheaper.
If interested in a b16 Go to www.osakajdmmotors.com the whole changeover kit is 1050 which is dirt cheap. And get the linkage.
Hopw this helps.
Old 11-11-2003, 10:19 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Re: B16 or ZC???
This question has been asked literally HUNDREDS of times. Try the search button in the top corner.
B16As are capable of 600+hp if you've got the moolah.
Do you have any experience with these motors? Or just opinion?
You want more acceleration on the highway? My B16 is reving at 5,000rpm on the highway, VTEC is just a touch of the gas away, and the car is gone. Same with stoplight racing, the shorter gearing of the B16 should put it on top most of the time with equal drivers.
"The nympho of info, I'm fuckin' what ya heard"
Old 11-11-2003, 10:26 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
LIES,
zc has 129 hp@6800 rpm and 106lb-ft@7300 rpm, (non-vtec) it comes out of the jdm 4g civic, you don't need to swap anything else to put in a zc but you will need to put in mpfi and an integra ecu to get the full potental, and the zc trannie has awesome gear ratio w/ a shitty 5th gear if your gonna use it for a daily driver this will provide lotta performance w/ good freeway gas mileage. nice for supercharging growing parts suppliers.
with vtec you will need the proper ecu (w/ vtec controller) and you MUST change to mpfi for the vtec to work.
d16z6 has 125 hp@6600 rpm and 106lb-ft@5200 rpm, (vtec) comes out of the usdm 5g civic si/ex 92-95 you will only need stock honda products easiest vtec to drop into your car but only sohc so less torque and not as racing perfered as dohc
b16a1 has 158 hp@7600 rpm and 112lb-ft@7000 rpm, (vtec) comes out of jdm 4g civic SiR parts should work from any other b16 engine, very cheep for the price, usually runnig 1500 w/ lsd and what i am saving up for.
b16a has 160 hp@ 7600 rpm and 111lb-ft@7000 rpm, (vtec) comes out of 6g civic Si 99-00 and a whole lot of performance parts but quite pricie compared to the other engines i mentioned.
above hp and torque as quoted from december 2000 issue of sport compact car.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 11-12-2003, 12:40 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: B16 or ZC???
oh dood, here we go again... Everyone get out your guns and shoot!!! I personally like the throw-together-ability of the D-series motors, but the B's are definitely capable of more. Do a search and you'll find a bajillion threads on this topic. However, if you plan on going D-series, I say get a Z6 sohc. I just did one, and also have a dohc zc. The zc is cool, but the aftermarket support is not great, and the parts are all goofy, like the timing belt is from a b20 prelude, the diz from a 1g teg, the bottom end parts from the si, head gasket from another, bearings from another, etc.... I like that the Z6 is just about as good on power, vtec, and all USDM for good parts availability! Just my $0.02!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-12-2003, 07:04 AM
Hatchin Hatchin is offline
Send a message via ICQ to Hatchin Send a message via AIM to Hatchin Send a message via Yahoo to Hatchin
keep in mind if you do a engine swap you most likely won't be putting those numbers down off the bat due to the fact that there will be engine wear and other types of factors, id say average for a stock car with a b16 is around 150 from dyno sheets i have seen
CRX Si
Old 11-12-2003, 01:50 PM
SiZ's Avatar
SiZ SiZ is offline
Re: B16 or ZC???
More like 140.
Old 11-12-2003, 02:31 PM
Originally Posted by SiZ
More like 140.
Depends on who does the swap also
CRX Si
Old 11-12-2003, 04:33 PM
SiZ's Avatar
SiZ SiZ is offline
What are you talking about? How does who does the swap affect how much HP the motor puts out? There's no way you're gonna see more than 140hp out of a stock 1st gen B16. You'd be lucky to hit 140.
Old 11-12-2003, 04:41 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
shyt ive seen around 130 for obd0 b16's if your lucky since they are older
seriously i would go with an ls swap, aftermarket support just like the b16, you can go turbo or you can even throw on a vtec head and you could go all motor
after i graduate i plan to have a turbo ls since i will be working full time it wont take long after i graduate, i did want to go sing cam but that might be for another project i just want this one finished before summer ends so i can buy my dream car
2002 Acura TL Type S
1991 Honda Crx Si
Old 11-12-2003, 05:01 PM
hey i say make up your own mind but yhea i forgot to mention that jdm hp isn't street legal, you will loose some hp by making it street legal, plus if you stay w/ a usdm then you will have more parts selection. if you have pleanty of free time, look for the b17a1 it's a 1.7 liter engine from the 2g integra GS-R w/ 160 hp@7600 rpm and 117lb-ft@7000 rpm. limited parts but kinda nifty of a catch.
Old 11-12-2003, 07:08 PM
SiZ's Avatar
SiZ SiZ is offline
Re: B16 or ZC???
Explain yourself. How is JDM HP different if its in your USDM car!?
And how is the USDM parts selection different than the JDM engines? Any engine other than the ZC has a USDM counterpart you can use parts for.
Old 11-12-2003, 07:12 PM
Re: B16 or ZC???
i didn't know we were talking 1st gen but depending on who does the swap and how good of a job still is going to effect power, for instance, improper wireing would rob you of power
CRX Si
Old 11-12-2003, 07:18 PM
SiZ's Avatar
SiZ SiZ is offline
Ya, but not like 10 or so.. If your car isn't wired properly its going to run fucked up (speaking from experience.. Mine was missing at least 50hp when I got it back the first time).
Its either going to be right or not right, its not going to have a bit of bad wiring and be making like 120hp.. Either it will be fucked and be making like 90hp, or it will be proper and be making full probably 135hp.
Even speaking of 2nd gen B16s, show me a dyno of a stock one hitting 150hp. There's no bloody way. I bet B18Cs don't hit 150hp totally stock.
Old 11-12-2003, 08:28 PM
Re: B16 or ZC???
its very doubful of 1st gen b16's putting down more than 130 to the wheels, the new k20's with 160hp only put 130 to the wheels, gsr's put around 146-148 to the wheels
1991 Honda Crx Si
crx zc engine or b16? hollaback6 '88 - '91 Civic | CRX | Wagon | Shuttlee 16 02-20-2004 08:42 AM
STOCK vs. ZC vs. B16 Jetts '88 - '91 Civic | CRX | Wagon | Shuttlee 13 12-22-2002 12:11 PM
Zc or B16 for me? Cfmotorsports '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-30-2002 08:09 PM
Poll- ZC timeslips? B16? EFsleeper '88 - '91 Civic | CRX | Wagon | Shuttlee 9 06-25-2002 11:25 PM
ZC or B16 swap? jusg19 '71-'87 Civic | CRX 10 03-12-2002 11:26 PM
