Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-12-2002, 01:27 AM
jusg19 jusg19 is offline
ZC or B16 swap?
i got a 91 civic hb dx. I found almost all i needed to know about doing the b16 swap, but then someone told me the zc was cheeper and not much different. I know the zc isn't vtec and the b16 is in the b16 has 1000 rpm high red line with 3 more ft lbs of torqe. but has anyone driven both and can tell me which one is better for the $$ and work? i'm stuck at the moment in a dilemma.
Old 03-12-2002, 01:37 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
lol me 2 b16 or b18c...
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 03-12-2002, 02:40 AM
CRX586's Avatar
CRX586 CRX586 is offline
I was thinking that too... ZC swap would save me money and be plenty fast... do I really need that extra 30hp/VTEC when I don't plan on racing (except when I'm late to school).
Anyone have experience smogging a ZC in CA??
Old 03-12-2002, 05:17 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
ZC followed by turbo for a cheap, drop in swap (plus wiring etc). B16A for the extra bhp but it requires a lot more effort than the ZC. B18 with turbo for the ultimate IMO
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 03-12-2002, 05:48 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
As Setanta said the ZC is a very easy swap, and will provide you with a huge power boost of your poor USDM engine.
However if you can afford it then the B16a is the better option, provided your working over the brakes and suspenion to suit.
To give you some idea of the differnce that 3lbft and 25-30hp makes Iv raced with a mate in my SiR Civic against another mates Si CRX, Even with the extra weight of the civic and a 2nd person I had no trouble at all in leaving him several car lengths behind in a dash to about 100kph (65mph)
If you look at a dyno graph for a B16a the torque curve is amazingly flat, and 90% of it is avliable over a much wider range than the older ZC.
Old 03-12-2002, 09:21 AM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
yeah, if money is an issue than ZC is the way to go. it is a ton less painful of a swap to go through.....i've done the b16 on my car, and have watched a zc swap on an 88 civic hb dx. Mine was a royal pain in the ass, even with tons of advance planning, prepurchased parts up the wazoo, and a guy working on it that had done the exact same thing before. The ZC engine will drop right in: no mounting kit required, possibly 86-89 integra axels, no vtec wiring, no VSS change overs... The only problem is that you have a dx with is sohc DUAL point injection....and you are going to multipoint in the ZC (or the b16). I would highly recommend getting a whole new conversion wiring harness....that's what my friend did.....i think it's a couple hundred bones....and its well worth it for the time saved. Oh yeah, and i think that you need the ecu out of either the 86-89 integra or the 90-93. The ZC is cheaper, easier and sounds more like what you need/want. 7200 rpms is still screamin......it's just not the high-tech growl of the b16 in its prime at 8k! later.....sorry for ramblin
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 03-12-2002, 09:40 AM
Digitalcivic Digitalcivic is offline
Send a message via AIM to Digitalcivic
The ZC mpfi wiring is simple. Do it yourself and save yourself some $$
red 91 hatchback
DOHC 1.6l ZC
DCsports header
gunmetal Motegi MR7 wheels
Old 03-12-2002, 01:32 PM
shadowboy's Avatar
shadowboy shadowboy is offline
Send a message via ICQ to shadowboy Send a message via AIM to shadowboy
also not to mention, that due to the dual nature of VTEC, the B16A will give you a lil better bottom end grunt over the ZC
btw, ZCs are only 106ft-lbs, so its a 5 ft-lb difference, not 3
Shawn
1979 Porsche 924S
1987 Honda CRX HF -- Project Chassis
1989 Acura Integra LS -- Project Parts Donor
Old 03-12-2002, 05:58 PM
91b16sedan 91b16sedan is offline
I first had a zc but the head gasket and the valve seals went on it. The zc was a great jump from the stock 92 hp d15. I then decided to do the b16 swap myself. It was not to hard to put in. The power increase over the zc is more then I accpected. The b16 does seem to have more low end grunt. The zc was a great motor but I like the b16 alot better.
B16a
Other Mods
14.8 @ 94 mph
Old 03-12-2002, 10:14 PM
If you plan on stickin with the car for a while, go b16. ZC is quick, but when it comes to speed, you'll eventually want more.
red 91 hatchback
DOHC 1.6l ZC
DCsports header
Old 03-12-2002, 11:26 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Well i've had both motors in my CRX and the B16 of course was more powerful. if you just want a quick little street racer and to save money then get the ZC. Im runnin the ZC now because it just seems alot funner to me to build up a 1.6L 130 non vtec beast. I want to eventually go turbo and throw on the GReddy 92-95 EX Kit.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
