Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 11-07-2003, 05:23 AM
adam_k adam_k is offline
help with brakes
when i push down on tha brake pedal, it starts creaking pritty bad.
it sounds dangerous...
what may cause this??
how can i fix it?
any info will be mad..
thx
Old 11-12-2003, 03:25 PM
mechy1barry mechy1barry is offline
Re: help with brakes
is it the pedal, or the front/rear brakes that creak. does it do it engine off/on?
Old 11-12-2003, 04:54 PM
Yeh its the brake pedal that creaks when you push it down to brake.
and it does it with the enging off( i think, i have to check)
what do ya reckon?
Old 11-13-2003, 01:21 PM
1.look for bulkhead/pedal bracket fractures.
2.check pivot bushes on pedal for wear and dryness.
it may help if you can disconnect the pedal from the pushrod to locate problem.
if pivot bushes are noisey,use a lubrication spray.
Old 12-18-2003, 02:17 AM
corvair corvair is offline
if its a 4 runner or pick-up there was a campain and they replace the pedal assy.
Need help with brakes! 99Alero Alero 0 02-24-2004 03:48 PM
Need help with brake lights?! imjoh1 Accord/TSX/Accord Hybrid 1 12-10-2003 12:02 AM
Help with brakes tammat68 Camaro Discussions 3 11-15-2003 12:18 PM
Need help with Brake lights.... Marc-OS DMC-12 3 07-17-2003 09:36 PM
HELP! with brake lamp speed-d3mon Accord/TSX/Accord Hybrid 5 02-24-2002 12:12 AM
