Go Back   Automotive Forums Car Chat > DeLorean > DMC-12
Old 02-11-2002, 05:42 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Need help with Brake lights....
The brake lights on my sweet 1982 Delorean are out! I made sure the bulbs were still good, and I replaced the fuse, but they still don't work. The blinkers and back up lights still work, but I can't figure out why the brake lights won't come on. Any help is appreciated.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 02-11-2002, 06:58 PM
1989 DX R's Avatar
1989 DX R 1989 DX R is offline
Send a message via AIM to 1989 DX R
Maybe the wire connection is out?
Old 02-15-2002, 11:32 AM
DMC12's Avatar
DMC12 DMC12 is offline
DeLorean Guy
two culprits
See if you get voltage to the wire where the PC board connects to the wiring harness (wedge something against the brake pedal if you are doing this solo). If you get power at the harness but no to the bulbs, the PC board may need repair or replacement.
If you do not get voltage to the wiring harness, then take a look at the switch that is on the brake pedal assembly. This little switch gets used every time you push on the brakes... so after 20 years its probably all used up. Replace it, and clean the contacts while you're down there.
SOLID! crew (circa 2002).
DeLorean moderator.
Old 07-17-2003, 09:36 PM
DMC 7008 DMC 7008 is offline
The connection between the socket and the board gets corroded . PJ Grady has new boards.
