Old 02-21-2002, 09:57 PM
speed-d3mon speed-d3mon is offline
HELP! with brake lamp
the console shows that i have a poblem with my tail lamp. you know the little picture of the car below the gas meter. my brake light bulb went bad. i put a new one in. light went away. then later on it comes back on. so i'm driving to kragen to buy another bulb. when i park i get out and take a look and my tail lights, everything is lit up fine. looked inside the trunk , the bulb is even lit. but according to that little display below the gas meter i have a problem with the tail lights? WTF! is there a relay or something that might be stuck? i need some advice. don't know what else it could be
Old 02-21-2002, 10:40 PM
desireems77's Avatar
desireems77 desireems77 is offline
Send a message via AIM to desireems77 Send a message via Yahoo to desireems77
Did you try having someone push your break pedal down inside the car, while you go out to the back and look? You might notice a light out only when the brake is being pushed.
2000 Honda Accord EX
Signant Silver
1993 Honda Del Sol SI
Samba Green Pearl
Old 02-21-2002, 11:54 PM
twizzaut's Avatar
twizzaut twizzaut is offline
when u cut your car off and turn it back on is the light off until u hit the break again? thats how mine was and 1 of the filaments was out in 1 of the bulbs
HöÑÐã§ 4 Lïƒê
Old 02-22-2002, 02:57 PM
this moring when i was warming up my car, everything was normal. i even pumped the barake and had my wife check to see if it was lit. everything was fine. but during my drive, the freaking light comes back on again. i was at a stop light and the just came on. so i'll take a look at the filament. and just put another new bulb in there. thanks for the help.
Old 02-23-2002, 11:58 AM
beastfromeast beastfromeast is offline
If the problem still running, you must have an short circutz somewhere or had a short. Try reseting your ECU, maybe it will resolve the problem if the short isn't there anynore.
Peace y'all, Raph...
Always lookin' for some adrenaline rush
Nothin' is like flyin'
NORDIC CREW #19 dans le pays de la neige...il neige, pis a Montreal, on a les plus belles femmes du monde!!
Old 02-24-2002, 12:12 AM
twizzaut's Avatar
my friend's brakelamp stays on but everything is ok so he just drives around like that all the time
HöÑÐã§ 4 Lïƒê
Need help with brakes! 99Alero Alero 0 02-24-2004 03:48 PM
help with brakes adam_k General Discussion 4 12-18-2003 02:17 AM
Need help with brake lights?! imjoh1 Accord/TSX/Accord Hybrid 1 12-10-2003 12:02 AM
Help with brakes tammat68 Camaro Discussions 3 11-15-2003 12:18 PM
Need help with Brake lights.... Marc-OS DMC-12 3 07-17-2003 09:36 PM
