Old 11-05-2003, 09:10 PM
90LShatch 90LShatch is offline
89 civic 4spd conversion ls swap
I found a 89 civic hatch with the 4spd for 500 dollars so i can have something to race with but i want to swap an ls motor in it with a 5spd tranny. now heres my question would it take alot of parts to do it like changing a auto to manual or would it be the same since it has clutch and everything there for a manual, so it would bolt up the same and or can you guys tell me what i will need thanks alot you guys are always there to help
Old 11-05-2003, 09:50 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: 89 civic 4spd conversion ls swap
Do a search, this has been heavily discussed... Basically, here's what you'll need:
Engine
Cable B-series tranny
OBDZero B-series ECU
Motor mount conversion kit
B-series shift linkage
Axles/Intermediate shaft
Rewire for MPFI/Add resistor box.
It's a pretty intensive swap, but runs great in the 4th gen. I know several people who have done it and it works fine. There are also several other sites like hondaswap.com or honda-tech.com or hybrid.honda-perf.org where you can get more info... It's been done lots, so you should find plenty of stuff. You'll probably end up spending a couple grand at least on it, after you buy all the little parts and pieces that you need...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-05-2003, 10:02 PM
GTA's Avatar
GTA GTA is offline
Whee..
you would also need dx/si hubs for the axles to work if i remember correctly.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 11-05-2003, 10:05 PM
SiZ's Avatar
SiZ SiZ is offline
And obviously you'll need the pedal assembly from a standard Civic also.
"The nympho of info, I'm fuckin' what ya heard"
Old 11-05-2003, 10:11 PM
GTA's Avatar
GTA GTA is offline
Whee..
but its a 4 speed civic, he was just asking if he would need as many parts as like and auto to manual conversion
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 11-05-2003, 10:16 PM
4GZChatch's Avatar
Re: Re: 89 civic 4spd conversion ls swap
oops, forgot to mention the hubs, thanks GTA...
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-05-2003, 11:00 PM
SiZ's Avatar
SiZ SiZ is offline
I've gone cross-eyed.
Maybe my reading skilZ need some catching up on, but is he not needing to convert from the 4 speed auto to a 5 speed LS tranny?!
Old 11-05-2003, 11:44 PM
no the car is 4spd i was using it as an example cause i want a b18a swap with the 5spd 90-93 ls teg. sorry for posting it i forgot to check to see if it was already posted til after the fact.... i felt like a damn newbie sorry thanks for the info also what is the resistor box that i need for the swap??? i thought ls swaps are pretty easy well they probably are compared to b18c probably
Old 11-06-2003, 12:06 AM
also i was wondering with the ls motor i know i need the swap like engine, mounts tranny axle but what about wiring since it is a standard civic, will it be more difficult than a si or something
Old 11-06-2003, 04:21 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
to answer your questio about a 4 speed to a 5 speed, all you need to do is bolt the 5 speed on and it will work, now for the b18swap thats a different story, but i am sure everyone has given you the info on switchin out the hubs and stuff
KoRnSaQ
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
90 Civic HF ZC SWAP 1.6 SOHC 4spd Tranny acesilvia '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-26-2005 06:55 PM
HELP:91 civic 4spd w/ls motor 4thgensvk '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-02-2004 02:13 PM
B16A2 into Civic 4spd CivicSiR7 Engineering/ Technical 1 01-15-2002 12:12 PM
