Old 08-02-2004, 11:48 AM
4thgensvk 4thgensvk is offline
Send a message via AIM to 4thgensvk
HELP:91 civic 4spd w/ls motor
i put a 92 ls motor in my 91 civic standard and it has been sitting for like 6 months now and wont start. my wiring is all f'ed upcuase i spliced into my old harness. right now the motor has the 92 injectors and distributor, should i change them to the 90-91. i also do not know which harness to use. any help would be great considering i have been bumming rides for about 6 months.
thanx
Old 08-02-2004, 11:53 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: HELP:91 civic 4spd w/ls motor
yeah..change both to 90-91.. 92 stuff is OBD1 and different..
SOLD!
Old 08-02-2004, 12:00 PM
91civicDXdude's Avatar
it depends on what ECU you're using. If you use an OBD0 ECU, then you need to use OBD0 distributor and/or obd1 injectors with resistor box, or obd0 injectors with ressitor box. either way, you need a resistor box wired with the injectors in OBD0.
If you are converting to OBD1, keep your distributor and injectors.
Old 08-02-2004, 12:18 PM
i am using obd-0 ecu and i can pick the injectors and distributor up cheap from a friend. before my swap i was running mpfi on my 1.5. so what harness sould i use?
Old 08-02-2004, 01:11 PM
marked001's Avatar
Moderadur
.do you have an injector resistor box?
SOLD!
Old 08-02-2004, 01:16 PM
yes i have an old one off like a 1st gen teg that i was running on my 1.5. but i have one of the newer ones laying in my garage.
Old 08-02-2004, 01:34 PM
marked001's Avatar
Moderadur
ok.. if you're using an injector resistor box, def. change to the 88-91 injectors..
SOLD!
Old 08-02-2004, 01:54 PM
my harness is no longer useable cuase my friend tried splicing into it and i didnt do my mpfi conversion myself so i do not know which harness to use. you think i should change to 88-91 civic injectors instead of 90-91 integra injctors?
Old 08-02-2004, 02:13 PM
marked001's Avatar
Moderadur
doesnt matter...they're all the same flow rate
SOLD!
