Old 10-30-2003, 12:11 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Needed to redo suspension?
I'm wanting to redo my whole front suspension and eventually my rear suspension so that the ride will be tons better. alli'me done so far is gotten a new passenger front control arm, and that was under a year ago.
so what all will i need to get, and what brands would be best? and i'm wanting to do all this myself, so getting an energy suspension bushing kit would rock but i don't have the presses and all to do it. but get me every detail you can think of.
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 10-30-2003, 01:04 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Re: Needed to redo suspension?
you dont have to have a press to do the ES kit. If you have a die grinder, torch and a hammer and some flat screwdrivers you can get them out. It takes longer is a bitch to do but there is no press involved.
Old 10-30-2003, 04:43 PM
Jay eS Iye's Avatar
Re: Re: Needed to redo suspension?
i have some screwdrivers and a hammer, actually two no die grinder or torch tho, i'm at college, and even at home i don't have those
Old 11-06-2003, 09:42 PM
Jay eS Iye's Avatar
Re: Re: Re: Needed to redo suspension?
bump
can someone give me a list of parts to get and brands?
Old 11-08-2003, 12:04 AM
Registered User
I will put it this way. If you dont have the torch and the die grinder, a place to work, a vise and the basic tools that are needed to get the bushings out then I wouldnt even attempt the bushing kit. It ended up taking me about 40 hrs for the LCA's and the rear trailing arms.
Old 11-08-2003, 09:27 AM
BullShifter's Avatar
Even with a press the bushings can be a bitch to remove, like Santas90Si posted. Most shops will charge a min. of 10.0hrs of labor for a poly bushing kit(full kit) install.
What exactly do you plan on doing to the suspension? When you say replace the entire suspension, that would include bushings, control arms, struts, spirngs, etc. You don't have to replace "the whole suspension" in order to make your car handle well.
What are your plans for the car? Street only, street/race, or race only? If it is gonna be for racing, which type? Autocross, Road racing, drag racing, oval racing . . . .?
Old 11-09-2003, 05:25 AM
Civicsiassasin91's Avatar
Civicsiassasin91 Civicsiassasin91 is offline
Send a message via AIM to Civicsiassasin91 Send a message via Yahoo to Civicsiassasin91
Damn good question... You'll save yourself alot of money if you answer the question. On my civic i added a tein basic damper kiy, new oem control arms/bolts and front/rear - upper/lower strut bars ,lowered it about 1". she handled like a dream. total cost was about $1600.00
I wilst judgeth thou, as long as thou posteth gayeth topics on the internet.
TLD's FINEST
Old 11-09-2003, 04:56 PM
Jay eS Iye's Avatar
well i'm going to go through all the paper work from my brother, but from what I know nothing has been replaced at all except the passenger upper control arm. I know the driver's side tie rod is bad (i can't get an alignment b/c of it), so i'll just replace both probably. The car is street car, once i get my turbo going (won't be for a while) it'll be street/race. I'm scratching the bushings unless i can find a shop that will give me a good deal. so basically just the regular suspension parts that go bad in time (like i said, i don't think anything has been replaced in a long time). oh and i'm probably going to get some coil overs b/c i want a slight drop on my car
Old 11-09-2003, 07:59 PM
replace the tie rods, ball joints, and only worn/cracked bushing with OEM parts. You can always upgrade to poly later if you need them.
Old 11-09-2003, 09:41 PM
Jay eS Iye's Avatar
if i do coil overs i need to get new shocks too right? what brands are the best pricewise
Old 11-10-2003, 08:57 AM
If you get "real" coilovers they should come as a package - spring/shock. Now if you want coilover sleeves you will need new shocks, for coilover sleeves I only recommend Ground Controls based off of people from AF. I generally do not rec. coilover sleeves at all!. Any time you lower a car you should replace the struts/shocks with part intended for lowering since stock stuts can not control the spring rates of lowering springs.
H&R // Tein - coilovers
Koni // Tokico - shocks
KYB AGX is NOT recommended to be used with coilover sleeves - all warranty's will be voided.
Who needs a suspension pro kit for 2004 GTO? bio_mach75 Modern GTO's (2004-2006) 1 04-15-2007 07:49 PM
Need Stronger Suspension in '94 Jeep GC JeepForever Grand Cherokee | Grand Cherokee SRT8 3 01-23-2006 02:42 PM
My CRX needs a suspension overhaul mrchris1979 Wheels/Tires/Suspension 5 04-13-2005 01:53 AM
Do I need new suspension? 19RaVeN96 Accord/TSX/Accord Hybrid 3 03-22-2005 09:13 AM
need help??????suspension........... Mram76 Off-Topic 2 03-04-2005 07:59 AM
