Old 10-27-2003, 01:00 PM
loopner74 loopner74 is offline
Angry 89 GP Dies when given gas!
Car starts and runs at an idle, however when given gas it just turns off. Almost as if key is being turned off, it does not sputter or try to stay running. We have replaced the fuel pump and filter as well as the coil pack, ECM and the cadalidic converter. Nothing is working. The car still has battery power and is staying charged. I have read several other reports of this complaint but still havent found an explanation or fix.
Old 10-28-2003, 09:29 PM
mudslinger82 mudslinger82 is offline
Send a message via AIM to mudslinger82 Send a message via MSN to mudslinger82 Send a message via Yahoo to mudslinger82
Some possibilities?
1st off, what kind of engine does it have? I4 or v6 (not familiar with what came in those in '89) Well, if you have/have acess to a volt meter, check the voltage at the TPS, assuming it has one. And check the voltage sweep from idle to WOT and then ohm it out. Also you could check and verify the throttle blade operation, take off the air cleaner tubing, shine a flashlite down it and see if it's plugged or full of carbon (the black stuff) Have you hooked a fuel pressure gauge up to it yet? What kind of pressures are you getting if any? Hope this maybe helps.
93 trans am dies when given gas red hot exhaust manifolds 9_trans_am_3 Firebird Discussions 4 07-01-2009 06:52 PM
92 Jimmy Dies When Idling rockavenger Problem Diagnosis 3 03-10-2009 09:52 AM
Clubwagon E-250 stalls when given gas?? Ferngee Club Wagon 1 12-27-2005 05:14 PM
engine dying when punching gas CarGuy5986 SC/SL/SW 2 01-17-2004 08:59 PM
1995 revs fine but bogs down when given gas rja116 Sierra 5 12-14-2003 01:55 PM
