Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-26-2003, 06:30 PM
nismo887 nismo887 is offline
Exclamation Speedometer, Cruise, and Odometer Problems
I have a 1989 240sx coupe that had been "bumped" in the rear by another car while the last owner had it. The HUD doesn't work, and the last owner said it was broken. Every once in a while the speedometer will twitch to 130, the max, and stay there for a while. While the speedometer is doing this my odometer doesn't register any miles, and my cruise control doesn't work either. I have no idea what's causing this problem, but if anyone knows I would appreciate some help.
Old 10-26-2003, 06:54 PM
J_Spec_NiTeMaRe's Avatar
J_Spec_NiTeMaRe J_Spec_NiTeMaRe is offline
Send a message via AIM to J_Spec_NiTeMaRe
it sounds like your whole gauge cluster is broken. the harness attached to your hud could be loose or damaged. there are many different things that could be wrong, but i would suggest taking out your hud and checking for loose/damaged harnesses or wires.
Old 10-26-2003, 07:21 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: Speedometer, Cruise, and Odometer Problems
it's a faulty gauge cluster. mine was the same way... odometer would stick and from time to time, speedometer would jump all over the place and go crazy.
very very common
only thing you can do is take out the gauge trim and try to pop in another one. i tried to get one off of ebay, the guy said it works, i put it in and it did the same thing, only worse.
just take it out and keep popping in another used one until it works. otherwise just forget about it, it really is no big deal.
438whp / 373tq - 11.9 @ 126
Old 10-26-2003, 07:55 PM
publicenemy137's Avatar
publicenemy137 publicenemy137 is offline
Send a message via MSN to publicenemy137
I have a 95 240, no speedometer but I have some odeometer problems. it also gets stuck time to time, I bought it used so I don't know how many real miles it's been driven. You would think it would be fixed after 6 years, sheesh
Old 10-27-2003, 09:38 AM
clutch240's Avatar
clutch240 clutch240 is offline
One thing you have to remember when changing out your gauges is nt to mess with the needles. My friend messed up the needles on his car when he put on blue gauges. Now they don't work properly, because they are run by senors and by touching them you mess up the sensors.
The ONE
[email protected]
Cardomain.com/id/moonlightknight
Update to: Cruise and Trans Problem 03impala9c1 Taurus | Taurus Wagon 8 04-12-2008 01:46 PM
'90 skylark 2.5 window, speedometer, and odometer problems short_trackkin_52 Cutlass Series 2 03-20-2008 12:34 AM
98 blazer speedometer and ODOMETER problem Juancm Problem Diagnosis 1 09-21-2007 08:39 AM
91 Acura LS Wiper, Cruise and Defog problems StevePT Integra 0 08-10-2006 07:07 PM
93 Lumina APV cruise and AC problem franksauto Lumina 2 06-03-2006 10:11 PM
