Old 06-01-2006, 05:53 PM
franksauto franksauto is offline
93 Lumina APV cruise and AC problem
Hi I have a 93 Chevy Lumina APV. It's a vacation home car in Florida. (so I need the ac) The air conditioning works but it only blows out of the panel vents when it wants to. It either blows out the floor or the defrost. When I press the selector button for the panel vents it's a gamble. Sometimes it works sometimes it dosent. At times I shut the car off, wait 20 mins then start the car & it does blow out the panel and the selector switches fine. I recently noticed that when the AC does not blow out the panel vents the cruise control does not work but when it does blow out the panel the cruise works fine. Very anoying. Not sure if it's a vacuume problem or a wiring problem. Any info will be greatly apriciated.
Thanks
Frank
Old 06-01-2006, 08:04 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 93 Lumina APV cruise and AC problem
Thanks
Frank
You hit it on the head...check you vacuum lines for cracks and your vacuum ball resevoir's integrity. Sounds like the resevoir isn't holding vacuum, and the vacuum operated accessories drop when vacuum level is low. I assume you still have the old style vacuum signalled cruise transducer. Check the lines to and from it also.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-03-2006, 10:11 PM
I Found It!!!
After a couple of hours of tracing vacuume lines I finnally found the problem. Vac fitting on the back of the throttle body had a pretty good crack in it. Replaced the 2 inch long hose & bingo. 2 hours to find it and 2 minutes to fix it. The car even runs better now.
Thanks guys
