Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-24-2003, 06:02 PM
c a m a r o c a m a r o is offline
Banned
best turbo system
whats the best turbo system out right now? are twin-turbos good or bad... i read that twin turbos actually slow down intake or something like that. is a garrett t-72 a good turbo for a v8 5.0l and up?
Old 10-25-2003, 08:55 PM
454Casull 454Casull is offline
Re: best turbo system
Define best.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 10-26-2003, 03:18 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: Re: best turbo system
to complete what 454 said define best for what aplication
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 10-26-2003, 03:54 PM
Anyway, the best of each application can be had if you have enough money.
Old 10-26-2003, 04:21 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
There is no single "best" for every application.
Beer tastes better upside down.
Old 10-29-2003, 02:53 AM
tha_new_guy's Avatar
tha_new_guy tha_new_guy is offline
I believe he means "Best" as in better than the rest... Geez, I'm a useless poster sometimes.
A twin turbo setup certainly does not slow down intake, but rather it "takes air in". Is that a complicated concept? I've heard of a guy who twin turbo'ed his 1990 Mustang LX (a 5.0). He used a sequential turbo setup, which means that a smaller turbo spools up quickly to produce less boost while a larger turbo spools up slowly to produce substantial boost. Therefore, you can still get decent off the line performance while maintaining top end performance that turbos are known for. However, this setup is difficult and costly because you need to replace a multitude of parts to deal with boost on a n/a vehicle (bigger injectors, bigger fuel pump, reprogrammed ECU to retard ignition during boost, possibly a new block, lower compression pistons, new piston rings/gaskets, heat shielding, etc). Also, to prevent detonation in f/i situations, you need an intercooler or in this case, twin intercoolers (or one massive one). On top of this, you need a custom headers, numerous mandrel-bent pipes, oil lines, turbo lines, and a free-flowing exhaust if you dont already have one.
That's alot to fit under the hood with a V8, isn't it?
That's my
AF Bay Area Crew
"Please try to refrain from smoking crack while typing. The literate community appreciates your restraint."
AF User Guidelines
Old 10-29-2003, 02:04 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
One type of turbo setup might be better for your application than another. What kind of car and engine are you wanting to turbocharge? There are so many things to take into account when think about having the best setup. Things like turbo size, intercoolers, number of turbos used, compressor maps, and the list goes on. To be general though I would say that Twin Turbo "Sequential' setups are better for larger displacement engines while a Single Turbo setup in better for smaller engines.
Old 10-31-2003, 08:34 PM
Banned
for a 3.4l v6, or a 5.7l v8... or 5.0l v8 305.
Old 11-01-2003, 06:11 PM
Polygon's Avatar
The Red Baron
I would go with a Twin Turbo "Sequential" setup.
Old 11-25-2003, 03:30 PM
Meyaht's Avatar
Meyaht Meyaht is offline
Send a message via AIM to Meyaht
sequential isnt as much as far as volume, but pressure.. they use sequenmtial in tractor pullers + high altitude private planes. if you pick the right size turbo, not only will you not worry about lag, but you'll have plenty of boost.. if you will up with 97 octane and have 8:1 compression ratio.. you can count on about 15psi after intercooler.. think twin turbo on V6 V8 applications, and one larger turbo with I4- I6 apps... for a 5.7 or 5.0 engine get a couple t-3's with a .64ish A/R. or smaller.
for the V6 definetly go smaller ro you wont reach full potential.
Old 11-26-2003, 11:04 AM
Banned
is t-80 better for a v8 than a t-3. and do all turbos necessarily have to make that gay rice noise? i like the way my car sounds, i dont want it to sound like an angry bee.
Old 11-26-2003, 05:15 PM
There are a couple of sounds related to turbocharging, the sound of the blow off valve, and the sound of the the turbine wheel compressing the air. Some blow off valves are very quiet, how loud just depends on the blow off valve. The sound of the compressor doing it's job depends greatly on the turbo and how much boost it's creating. It's possible to create an ultra quiet turbo system, many stock ones are.
But I don't see why it matters. That's the ricer mentality only in reverse. If my car ran a 10 second 1/4, but sounded like a weed whacker, so be it. The thing that people hate about ricers is that they like to present their cars as ultra fast, race machines, when in actuality they are bone stock. If your car is fast, the people who's opinions actually matter will respect your car no matter how it sounds, because anyone who discriminates based on the sound of a car doesn't know anything about them.
Old 11-27-2003, 12:16 PM
Banned
u seem to know a lot about rice... are u a honda owner?
Old 11-27-2003, 03:31 PM
You don't need to own a Honda to know about rice.
Old 11-27-2003, 04:40 PM
Actually I'm a Dodge and Mazda owner.
I need the Best of the best Braking system Max2hot Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 6 06-15-2004 03:11 PM
Two Questions: Best Security System? Best 5.1 Amp? AZFlyingDiver Grand Cherokee | Grand Cherokee SRT8 14 05-17-2004 03:31 PM
best turbo/turbo kit for integra GSR???????need help tegGSRrider Forced Induction 6 12-19-2003 07:56 PM
Best Catback system performance wise? Rein Forced Induction 16 04-21-2002 04:07 PM
Best fuel system cleaner 95vteclude Engineering/ Technical 14 02-18-2002 07:38 PM
