Old 02-11-2002, 12:08 AM
95vteclude
Guest
Posts: n/a
Best fuel system cleaner
I'm going to change my fuel filter and i want to clean the fuel system.. is there a product you guys recomend that really works for cleaning injectors and carbon deposits from the engine?
Old 02-11-2002, 09:32 AM
FLAWLESS FLAWLESS is offline
Send a message via AIM to FLAWLESS
It seems almost universally agreed that Chevron Techron is the best. I've had good results with 3M also but it's harder to find.
98 Civic LX - Bottle-Fed
Old 02-11-2002, 10:44 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
Techron is really good, but see if you can get your hands on some Wynn's cleaner, it works really really good.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Old 02-11-2002, 08:12 PM
praxis praxis is offline
JusticeBrothers has all kinds of cleaners and they all work extremely well.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 02-12-2002, 12:16 AM
changedagame108 changedagame108 is offline
Chevron with Techron has worked the best for me and I've really noticed a difference.
Old 02-12-2002, 08:18 AM
95vteclude
Guest
Posts: n/a
Does chevron have a treatment that you buy at the station or do you guys just use their gas and that cleans it? thanks for the tips.
Old 02-12-2002, 07:56 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
It's a concentrate:
http://www.chevron.com/prodserv/nafl...d.shtm#techron
Good stuff.
I also like gumout's "Regane":
http://www.pennzoil.com/TechData/pds...pdf/regane.pdf
It seems to be a little milder for regular (every 3k miles or so) use.
Always add additives to a full tank of fresh gas, then run the tank nearly dry. It's also a good idea to change the oil after that too.
Personally, I put in a bottle of Regane a little before 3000 miles, and then change the oil at around 3250.
Old 02-14-2002, 01:59 AM
PiNoY GsR RaCeR PiNoY GsR RaCeR is offline
Humm...I should buy some of this. It should free up some HP!
1994 Acura Integra GS-R
Performance Mods:
AEM Intake
DC Sports Headers
GReddy Cat Back Exhaust
Ground Control Coilovers
Exterior Mods:
WW Body Kit
PIAA Low Beam Bulbs
'98 Style Integra Taillights
Old 02-14-2002, 02:01 AM
Btw, how much is the Chevron TECHRON concentrate fuel system cleaner?
Performance Mods:
AEM Intake
DC Sports Headers
Exterior Mods:
WW Body Kit
PIAA Low Beam Bulbs
Old 02-14-2002, 09:07 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
some pressurized fuel system cleaners that shops use can work really well too. they basically run your car off of this shit (some kinda detergent) for a short time and it blows a lot of carbon out. obviously not your every 3000 mile treatment type thing.
Old 02-14-2002, 06:30 PM
fritz_269's Avatar
Both Regane and Tecron run about $7/12oz - enough for one Honda-sized tank.
Old 02-16-2002, 11:31 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
someone said to add it to a full tank of gas, thats incorrect, you are supposed to add the techron to an empty tank then fill your tank full so it mixes with the gas instead of just sitting on the top of it.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-17-2002, 12:34 PM
KrazyGoku KrazyGoku is offline
Smile
i think what the guy meant was not to add the cleaner to an empty tank = )
Vtec not Vtech
Old 02-17-2002, 09:16 PM
90civichbsi 90civichbsi is offline
Send a message via AIM to 90civichbsi
i used some RXP fuel system/combustion chamber cleaner and it seemed to work pretty well
My 1990 Honda Civic Si
i/h/e
gude head
gude cam
gude ecu
2" lowering springs, camber kit etc.
wings west front bumper
powder coated GSR rims
Old 02-18-2002, 07:38 PM
fritz_269's Avatar
You're right - I should have said to add it WITH a full tank of gas.
Adding it to a full tank isn't so bad, it'll slosh around an get mixed pretty fast. But adding it to a nearly empty tank and driving is quite bad - it'll make your car run very rough and may even start to corrode some fuel system components. It needs to be diluted with the gas.
But the best is to do as crxlvr says - add it to the empty tank at the gas station right before you fill 'er up.
best fuel injector cleaner?!?!?!?! slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 13 11-18-2014 05:21 PM
Anyone use fuel system cleaners? joshua_msu Taurus | Taurus Wagon 14 04-28-2006 10:10 AM
fuel system cleaners? wwh975 Passat 0 03-24-2004 09:46 PM
Best Fuel system cleaner? Strider Xero General Discussion 1 05-12-2003 07:17 AM
Too much fuel system cleaner sciguyjim Engineering/ Technical 2 09-11-2001 09:31 AM
