Old 10-24-2003, 05:16 PM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
Turbo Question
Been looking for a turbo. Anyone hear anything good....or bad about the FP sleeper 16? Also been looking at there Big 28. I'm looking for quick boost at about 3500 or less. Looking to put down 400 plus at the wheels
Old 10-24-2003, 07:25 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
the sleeper 16G is almost $1200
I dont see myself buyin a 16G for that much when u can get the FP red for $100 more
-Agim
Old 10-25-2003, 09:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
If 3500 is your goal, then even a 20g will meet that criteria I always say go with the largest turbo that spools where you want it to. And a 20g is less than 1200... I believe Mike at SBR said he could build even the TOD6H 20g that I ran for a while for 999, but give them a call first. That spooled around 36-3700, and the cams I have hurt spool. If thats pushing it too much, a TDO6 or TDO5H 20g can also be made. The EVO16g is also an atractive option at 579 shipped, and it spools below 3500 but can still run 11s if you push it. My buddy let me drive his "small 16g" 2g last night. I screwed the pooch on the launch (1.9, ouch) but ran a 12.07 at 114.7. With even a crappy 1.8 that run had 11s written all over it...
What turbo to buy are always tough questions to answer, even after having run a dozen different turbos myself.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-25-2003, 07:15 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
The EVO 16G is a very nice option, cheap and will be able to get you good times and traps. When Its time to rtire the 14B, the EVO willl be my choice.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 10-26-2003, 03:30 AM
Re: Turbo Question
Well just to give my background i want to build a road race car more than an 1/4 mile car. So i'm looking for quick spool that holds till redline. Also i plan to make a bigger chunk of power from the engine itself than most who just want to bolt on a turbo. 2.4 stroker kit with a fully worked head is what i'm looking to do along with turbo upgrade. And you know all the other goodies of course. Call me crazy but the car is gonna remain AT through all of this.
Old 10-26-2003, 05:13 AM
look into head work and alot of porting also
-Agim
Old 10-26-2003, 03:58 PM
Talon007's Avatar
If your looking for torque do NOT touch the head, preferably run a 2G head. If you port it you will lose the bottom end. You want to find some cams that will work for your application.
Chris Clark
www.Talon007.com
Old 10-27-2003, 12:40 PM
AF - Advisor
IF you are going with a stroker, you should have mentioned that in the first post. That makes a huge difference in what turbo you should run. A 16g will run out of breathe real soon on a 2.4 liter. And the extra displacement will spool a 20g like a 16g. I would highly recomend a 20g (at least tdo6 or tdo6h), or a GT12. And the ballbearing design of the GT 12 will just help spool further. I too would leave the head alone, but a pair of 264 cams wouldnt be a bad thing. With the extra displacement the motor is going to need to breathe more, hence the empahsis on the cams and the larger turbine wheel.
Kevin Jewer
Stupid turbo question? Do a CT 26 turbo need a gasket seal or seal? DrifterRZero MR2/MR-S 2 11-19-2010 02:52 AM
Tranny questions and turbo questions... Marc-OS 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-08-2004 01:40 AM
Turbo Question criscross79 Impreza/9-2x/Outback Sport 8 01-28-2002 04:47 PM
Turbo question Initial_E 911 4 12-28-2001 06:51 PM
Turbo question? MDurs Engine 3 12-05-2001 06:36 PM
