Old 10-22-2003, 04:58 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
twin 5.0
Well Im starting the begining stages of planning this out. I currently have a Buick Grand National and I love the performance of a turbo car. But I also love driving a fivespeed car. I have two TE-44 turbochargers sittin in my grage so im thinkin of a comletly built 5.0 twin turbo five speed car . wadua think?? I'm figuring on a complete rebuild with forged pistons and Steel crank ect. etc. I've noticed that alot of forced inducted 5.0 don't run real hight boost (at least what I have seen). So im planning on dropping the compression to 8.0:1 and spraying alky. If my buick can handle 24PSI on pump gas with no knock then why can't a 5.0 handle 20-24 PSI. If anyone has any questions or consernes or advise (as since I am walking into this blindly.) any help would be appericated.
Thanks
Andy
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 10-22-2003, 11:31 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
I have a general question - i was told that a single turbo is often better then a twin set up. I was told this was because a single set up is more efficient to spool up then twins - but if this is true then why would anyone go for a twin set up?
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 10-22-2003, 11:58 PM
audi&benz's Avatar
audi&benz audi&benz is offline
Send a message via AIM to audi&benz
If he is putting two turbos in the 5.0, he shouldnt have any problem spooling them up. The large displacement of the 5.0 will help spool the turbos faster than some small 4 or 6 cylinder.
Good luck and post those pics as soon as you do it.
2002 Subaru WRX Silver
Old 10-23-2003, 03:32 PM
Chrisv006 Chrisv006 is offline
Send a message via AIM to Chrisv006
Re: twin 5.0
Well, in an engine of that size, single or twin should not matter as much as it would in say an RX-7.....But in a car like that, its easier to spool two small turbos than one big turbo....Nothing lags like a single turbo wankle....
-Chris
Old 10-23-2003, 03:52 PM
gizzmoe gizzmoe is offline
Re: Re: twin 5.0
I think that would be a really fast stang. I see that ur from IL and was just wondering if you live anywhere near naperville. If you do have you ever gone down to 75th street and rout 59? I was just wondering this because I have seen a black Grand Nation there before.
Old 10-23-2003, 04:15 PM
Hypsi87's Avatar
No I live down in peoria but I think I know whoes gn your talking about. my buddy lives up there and if it is the same one then that is a low 10 sec. street car. (in other words don't mess with it.) . Im up there about once a month around that area. mabye we could get together and run em . just kiddin.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 10-23-2003, 05:20 PM
boosted331 boosted331 is offline
Re: twin 5.0
Thanks
Andy
You really need to do a lot more reading before you dive into something. For starters the stock 5.0 block is gonzo after 500 RWHP, you're gonna need to dish out around 1500 for an R302 or dart block, or an A4 if you can still find one. 20-24 psi on TE44's, might want to re-think your plan. A pair of TE44's on a decently built motor with good heads + intake would be maxed out before they hit 24 psi, you would be hard pressed to hit 20. If you want to run 24 pounds of boost from a pair of turbos or a turbo on the street, look into something bigger like some 66's or even bigger. At that point you're going to be making too much power for any clutch or standard trans to handle, and if you want to do any kind of hard driving at all you're going to need to put a big drag radial or an E/T street under it, and even then it will roast the tires doing 100.
Old 10-23-2003, 09:05 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: twin 5.0
Peoria huh? A big city in the middle corn, lol. I was there over the summer, drove 2 hours through corn fields till we hit the city. Nice place!
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 10-23-2003, 09:19 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
peoria ha, sounds familiar. is that anywhere near wauconda or fox lake?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-23-2003, 10:48 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I was never good at Geography
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-24-2003, 12:11 AM
DavidovSpeedWRC DavidovSpeedWRC is offline
Send a message via AIM to DavidovSpeedWRC
Out of curiosity, how would a single turbo setup happen on a "V" engine?
I would assume a twin-turbo V8 would have one turbo on each manifold. Then where would a single turbo be placed to allow balance in the flow?
Also Hypsi87: What kind of HP numbers are you putting down on 20-24 PSI??
-1987 Mazda RX-7 Turbo II-
Voted #7 in the top 10 cars in 1987 by Motor Trend!
-Driving Sideways Since 2001-
Old 10-24-2003, 11:14 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Here is how.
I don't have time right now, but I would only go to 18psi with those turbos, and boost your comprssion up to 8.5-8.75.
Like what was mention your block will fail. I am going with a 351W, the stocks block I have seen handle over 650 pretty easly, anf they are a lot cheaper, and have more cubes than the others that were mentioned.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 10-24-2003, 02:39 PM
When/If you add a FMIC there is going to be like 5 miles of piping hehe...with a twin setup, I think it could be made to have a goodbit less piping....
-chris
Old 10-24-2003, 02:54 PM
SkylineUSA's Avatar
Its a V8, piping what piping?
As long as you have a reasonable amount of compression it will be fine for the street, its all in the way you build the engine. How you want the power band to hit.
You can always use a VORTECH Aftercooler.
Old 10-24-2003, 03:24 PM
SkylineUSA's Avatar
I am a novice when it comes to this stuff. Go to www.turbomustangs.com/forums these guys live turbo stangs day and night. I get a lot of good info from them.
Where is oil sending unit 98 Explorer 5.0 Hedhunter Explorer | Explorer Sport Trac 2 02-13-2010 01:19 PM
WTS: 1979, Ford Mustang 5.0 Auto, Coupe, 105,000 orig. miles kevin2e Classifieds 3 12-02-2009 10:49 PM
1986 5.0 turns over but won't start 86_5.0 Mustang Problem Diagnosis 2 06-24-2009 05:50 PM
S-Trim Supercharged 5.0 vs Twin Turbo 5.0 flip888 Mustang Talk 12 03-11-2006 03:02 AM
WIP: 1992 Twin Turbo or Single Turbo 5.0 302 or 5.8 351 Mercury Cougar CamaroSSBoy346 WIP - Street 11 01-30-2005 08:59 PM
