Old 03-03-2006, 07:59 PM
flip888 flip888 is offline
S-Trim Supercharged 5.0 vs Twin Turbo 5.0
I was reading up on home-made turbo systems over at turbomustangs.com for the past few months and since i wasplanning on putting an s-trim on my 1990 gt before i got into turbos, i thought i would ask your opinions on the subject.
I was thinking that i would make a jy intercooled twin turbo setup using 2 mitsubishi 14b that would cost about $1300-1500 total for everything i need (i have a friend that has the exact same system and thats what he said it would cost at the minimum). From what ive found out the most boost i could run is about 6-8 psi on 92 octane depending on the intercooler and stuff. With an AOD i could build boost off the line which is cool (for hella burnouts at least heh).
But on the other hand, with the $2500 supercharger i can supposedly run more boost even without the intercooler (with an IC on the SC it would be a lot more boost i assume), have less heat in the engine bay, can install it probably 5x-10x quicker. Especialy with all the exhaust/intake pipes/flanges to fab up for the turbo.
I know the S-trim would make the car faster, but with 90% street time and 10% strip it doesnt really mater, im more into it just for fun.
Hmm now that i typed this out im leaning twords the S-trim.
Old 03-03-2006, 08:37 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: S-Trim Supercharged 5.0 vs Twin Turbo 5.0
Thats what I did lol. I'd love to have a turbo on my car. But I bought an S-trim instead. Its will be quicker and easier to install. The turbo thing is great but for a first time boosted v8 experiance I'd suggest an S-trim. These little blowers can move some air and have put cars down the 1320 in the high 9's.
1969 Cougar
357w & TKO - 475hp
Old 03-04-2006, 02:16 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Don't look at just the boost PSI, I would bet that you can get more power out of an 9lb jy setup over a 12lbs S-trim.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-04-2006, 07:58 AM
351wStang's Avatar
I do agree. It is very possible to make more power with a couple t3 turbocoupe or equivalent turbos. But for simplicity I'd suggest the S-trim. Especially and this being a first time thing.
1969 Cougar
357w & TKO - 475hp
Old 03-04-2006, 04:43 PM
SkylineUSA's Avatar
Totally agree
Old 03-04-2006, 10:34 PM
351wStang's Avatar
You know you can just lemme know when your ready for me to take that T76 off of your hands Tony . BTW is that a tang housing GTQ or what?
1969 Cougar
357w & TKO - 475hp
Old 03-05-2006, 03:27 AM
SkylineUSA's Avatar
David,
What the heck is a tang housing? I never heard of that. Its a GTQ
I'll give the T76 after I blow up my engine
Old 03-05-2006, 08:29 AM
351wStang's Avatar
Tangenitial housing or some shit. Supposed to be much better power wise. I think its some kinda offset.
1969 Cougar
357w & TKO - 475hp
Old 03-05-2006, 01:04 PM
351wStang's Avatar
Here ya go Tony, and anyone else that is curious about the difference between a "tangential" turbine housing and an "on center" turbine housing.
http://www.turbomustangs.com/smf/ind...?topic=11157.0
1969 Cougar
357w & TKO - 475hp
Old 03-07-2006, 04:22 PM
hmm, some very good info
Thanks
Old 03-10-2006, 12:11 AM
Whathits14 Whathits14 is offline
14bs are way to small for a 5.0L engine. 2.0L engines a 14b (1g dsms) is considered a tiny turbo...390cfms is way too small for a 5.0L. Check out garrett air researchs turbo site they have some excellent, yet easy to understand formulas to calculate the proper size turbo(s) for your engine goals. http://www.turbobygarrett.com/turbob...ch_center.html
Twin turbo setups are more complicated than a supercharger setup but will make more power in the end. If you know your car in and out 5.0L turbos are great, and most of the TT mustangs out there are foxes, if you can weld and fab shit yourself you can have an amazing setup for a fraction of the cost of an average supercharger setup. Turbomustangs.com is IMO one of the best sites to learn about turbochargers, regardless of platform. There is a huge wealth of information there and I find myself there from time to time referencing info for my DSM. It is an amazing site.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 03-10-2006, 06:54 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
I agree, I'd run at least 60 trim T3's on the street, maybe dual hybrids if the car sees a lot of track use. It's not like the 5.0 is lacking for bottom end, so you can be really free on slower spoolups....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 03-11-2006, 03:02 AM
SkylineUSA's Avatar
Yep, They make very good points.
