Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 10-17-2003, 01:35 AM
Hawaii 5-0 Hawaii 5-0 is offline
Easiest/best way 4 running wiring thru firewall?
I have a '98 Pathfinder. Does anyone know what the easiest/best way is for running wiring through the firewall into the engine compartment?
Nothing really big, maybe just two 16 gauge wires for a switch.
Thanks in advance...
Old 11-21-2003, 10:36 AM
rhspuckstopper6 rhspuckstopper6 is offline
The easiest way that i found was run it up thru the fender to the door, from the door go thru the little hole in the dash where the speaker wires run from and then your in
Old 12-07-2003, 07:24 PM
BFinlay BFinlay is offline
Re: Easiest/best way 4 running wiring thru firewall?
Run it through an existing gromet in the firewall where other wires run through into the passenger compartment. no holes to drill and your not going to see it.
Old 12-16-2003, 05:24 PM
zol zol is offline
BFinlay has it right. Use an existing grommet and if you really cant locate one then drill a hole but make sure you fit a grommet & if you have never done it before be sure you get the right point of entry/exit on both sides so easily accessable.
please tell me the best way to punch through firewall paulmalcom Altima 4 07-31-2007 06:44 AM
'06 ford 500: Where is best place to drill thru firewall to run power wire? c690 Five Hundred 2 12-25-2006 09:23 AM
best way to wire Picquerist Car Audio 8 11-14-2004 02:31 PM
running wires through firewall boobalinks Ram Pickup | Ram SRT10 7 10-21-2004 01:00 PM
Need Help With S40 Wiring Thru Firewall TechKnight S40 0 01-02-2004 07:00 PM
