Old 11-13-2004, 07:32 AM
Picquerist Picquerist is offline
Send a message via AIM to Picquerist
best way to wire
i have
the h2 15.2 http://orioncaraudio.com/subwoofers/sub_H2_series.asp
and a power acoustik2400 http://caraudio.avdeals.com/amplifiers/A2400DB.htm
what would be the best way to wire these together?
Old 11-13-2004, 11:36 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: best way to wire
wire each sub in series, and then wire the pair in parallel
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-13-2004, 02:26 PM
only 1 sub
Old 11-13-2004, 02:40 PM
will running at 1ohm be safe on that amp?
Old 11-13-2004, 02:52 PM
sr20de4evr's Avatar
oops, lol
you'll have to wire in series, 1ohm would not be safe with that amp
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-13-2004, 04:11 PM
so that'll have the amp only running at 4 ohm?
how would i be able to get it to run at 2 w/o getting another sub
Old 11-13-2004, 04:32 PM
sr20de4evr's Avatar
you can't, not with a dual 2ohm sub
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-14-2004, 01:56 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
isnt that amp suppose to be 1 ohm stable
Old 11-14-2004, 02:31 PM
sr20de4evr's Avatar
you may be right, it doesn't have an rms power rating at 1ohm, it doesn't say that it's 1ohm stable, but it has that maximum power handling at 1ohm thing at the bottom. Then again it also says "bridged maximum power handling @ 1ohm" and it's a mono amp which means it can't be bridged....so I'm not sure what to think.
'01 Black Sentra SE
'05 Silver WRX STi
