Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-27-2004, 01:36 PM
boobalinks boobalinks is offline
running wires through firewall
I am a Fire Chief and need to run wires for my radio and siren to the battery. Is there a plug in the fire wall of the new 2004 ram 1500 quad cab that I can remove to run the wires through? I do not want to drill any holes through the fire wall if I do not have to. Can anybody help me?
Old 01-27-2004, 04:13 PM
kapler24's Avatar
kapler24 kapler24 is offline
Re: running wires through firewall
have you tried to run the wires through the rubber piece that the steering linkage runs through the fire wall or try the rubber piece that the shift cable goes through. thats where i ran my wires through when i connected my amps to the battery. if you need a picture i can take one for you just to give you an idea of where i ran my wires through.
Old 10-19-2004, 07:55 AM
KittyKat22.2 KittyKat22.2 is offline
Re: Re: running wires through firewall
Hi..I am also trying to run the wire to my battery, can you send a picture so I can see exactly what it looks like?...I have the stereo out and the panel off, but can't figure out where I would run the wires..I printed how to install AMP off the internet, so I am ready, but am on hold due to can't find the exact place and wouldn't want to drill a new one...
I also installed new speakers myself...so the AMP is all I need..
Thanks
Old 10-19-2004, 07:56 AM
Thanks
Old 10-19-2004, 07:58 AM
Hi, Did you find where to run the wire for the AMP?
Thanks
Old 10-21-2004, 07:59 AM
Cool How to install a Equalizer
Hi
I am trying to install my equalizer in my truck
It has 3 wires, one black/ground
red-fuse/power
orange/? I don't know where this one goes
Can any one help?
Thanks
Old 10-21-2004, 10:42 AM
dirty dan dirty dan is offline
There is a rubber plug in the firewall. Look from under the hood below the brake fluid reservior. As I recall it's held in with 2 screws. Unless I had a large amount of wires to pull, I would make a small hole or slit in place and pull through.
Old 10-21-2004, 01:00 PM
Thank you I found it and did hook it up...thanks
