Old 10-13-2003, 09:07 PM
93hase 93hase is offline
Cut Wire Harness for stereo, screwed, help me!
I recently bought a panasonic deck off this guy, its a 45 W x 4 Channels. My stock wiring harness was cut, and I need some help finding out how to fix it so I can plug all my stock speakers into the back of the panasonic deck so they will work. Cause right now I only have the rear two working cause I ran a wire up the passenger side. Any suggestions? (I think I may have to buy a harness of some sort?)
Old 10-13-2003, 10:48 PM
gonzo747 gonzo747 is offline
OEM Pwer colors ------- aftermarket radio or harness
Battery/Memory: white with blue ------ YELLOW
Ignition/Accessory: Yellow with red ------ RED
Ground: Black ------ BLACK
Dimmer: Red with Black ------ ORANGE with White
Amp Turn on: none ------ Blue with White
S P E A K E R S
FRONT --
Right +: Red with Green ------ GRAY
Right - :Brown with Black ------ GRAY with Black
Left +: Gray with Blue ------ WHITE
Left -: Gray with Black ------ WHITE with Black
REAR --
Right +: Red with Yellow ------ PURPLE
Right -: Brown with White ------ PURPLE with Black
Left +: Blue with Yellow ------ GREEN
Left -: Gray with White ------ GREEN with Black
Old 10-14-2003, 08:44 AM
Re: Cut Wire Harness for stereo, screwed, help me!
Might help me a bit, i'll have to see. Any other suggestions?
Old 10-14-2003, 02:49 PM
akina_speedstars akina_speedstars is offline
The wiring code the other guy posted is what you can work off of.
You can go to a junkyard, cut the wiring harness from the car, splice that to your cut wires, get a wiring harness that will work between your deck and the car's harness and connect them. Or, you can just splice and wire directly between the wires. The harness just lets installation become easy. In your case, you will have to splice and solder either way. Crimping connectors will make it easier so you don't have to solder in a cramped area.
Old 10-14-2003, 03:04 PM
accordztech accordztech is offline
Send a message via AIM to accordztech
u can get the OEM one from honda for like 10 bucks...or just hot wire them up.
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
wire harness for after market stereo install XC90 marc_baltique General Discussion 1 06-05-2009 08:54 AM
99' Ram Quad Cab -I Need Seat belt Help PLEASE!! nrosssr Ram Pickup | Ram SRT10 0 03-30-2009 05:42 PM
I Need Da Radiowiring For A 94 Honda Civic Someone Cut Wire Harness Off thridparty '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 08-13-2005 11:44 AM
Stereo wiring harness for 2005 Sportage? MtnVwPilot Sportage 1 05-26-2005 12:10 AM
Please Help! Wiring Harness for 89 Lemans?? BananaLee General Discussion 1 12-02-2004 09:51 PM
