Old 10-13-2003, 01:09 PM
mhavens mhavens is offline
Question 99 Caravan - slow cranking - starter?
99 Grand Caravan (3.8L) has recently been taking it's time cranking when we turn the key. It usually turns over after 1 or 2 cycles. I put the battery on a trickle charge overnight, and it still had the same problem. Is this the starter beginning to go out? My Ford Ranger did this recently until it wouldn't start at all. I'd like to get it fixed before it goes DOA on the road. Also, sometimes the gauges on the instrument panel go out, but then work most other times. Suggestions?
Old 10-17-2003, 05:49 PM
Re: 99 Caravan - slow cranking - starter?
bad battery. Probably a bad cell. Replaced it and all is well.
Old 10-29-2003, 08:47 PM
Pam Pam is offline
did you ever fix this problem? My dad has the same prob w. a 94 caravan. clicks but slow start. replaced the battery twice in one month. (no cheapy either both die hards)
96 Taurus slow cranking bukuballs Taurus | Taurus Wagon 6 06-07-2011 06:25 PM
01 tahoe starter pre cranking/stuck robbv Tahoe 9 01-09-2010 07:04 PM
Caravan only gets to 25mph then slows dieter Caravan | Voyager 4 08-06-2009 05:23 AM
slow cranking, sometimes? joe92k1500 C/K 5 08-21-2004 10:33 PM
94 XJ VERY slow cranking 94XJ Cherokee 1 07-22-2004 07:03 PM
