Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-07-2010, 06:01 AM
robbv robbv is offline
01 tahoe starter pre cranking/stuck
hey guys.....new guy here....i would always hit the AF forums for tips on painting and stuff....but never really for a problem with my RIDE....till now.......so finally decided to become a member.....Soooo here it goes
ive asked this question many times on other forums..but always with no ANSWER....seems like my problem isnt very common...1 guy even mentioned Buyin a new Truck.....heh....with these times....i dont think so ...............and sides i worked my ass off to pay off my truck...........there nothing like finally seein that title under ur NAME........
ok so this started in the summer ...and stopped for a while...but now its consistent..
I put the key in the ignition and turn it once..and the truck tries to start before i can fully turn the key all the way....and it sounds like a mess...engine runnin and the starter screeching....
to stop this and have the truck run normal...i have to quickly put it into Drive or Reverse and everything is fine.............but when i go to Park or Neutral ....the mesh of engine/starter noice is present.
ive had the ignition switched / key tumbler changed....i believe the starter has been changed too......
what other things should i look into that might be causin this problem?
fuse?
relay?
solenoid?
park activator?
some wire makin contact?
Old 01-07-2010, 09:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 01 tahoe starter pre cranking/stuck
First check ign switch.
MT
Old 01-07-2010, 09:52 AM
yea.....i switched the ignition..even have a new key .....its still doin it.....the tumbler was also switched.....
Old 01-07-2010, 10:45 AM
MT-2500's Avatar
AF - Advisor
Switching is not checking.
Switching is throwing parts at it.
Checking is proper testing.
Check switch for shorted or burnt or crossed wire.
Check for 12 volts on start wire from switch in the wrong position.
Should only have 12 volts in start position.
Any adjustment on switch position ?
Any add on remote start crap on it?
MT
Old 01-07-2010, 10:56 AM
no remote crap added..........the only other wiring near or around.. are the wires n stuff that control my air valves for my suspension air bags......but i'll check the voltage on the wires
Old 01-07-2010, 11:28 AM
MT-2500's Avatar
AF - Advisor
Find the start wire at switch and check it.
MT
Old 01-07-2010, 08:01 PM
i'll try this when i get the truck back....the truck has been at my kid brothers place....
its been REALLY COLD here all week...i just found out he's been takin it to work in the mornings..with no problem starting..........so i guess i have to wait till the problem begins again to do the proper testing? =/
Old 01-09-2010, 09:44 AM
j cAT j cAT is offline
I would check that the added wiring is not interferring with the movement of the ignition switch operation...
with your description its engaging the starter in the ignition on mode rather than the crank position..?
Old 01-09-2010, 09:48 AM
yes....its engaging the starter in the Ignition On Mode....rather than the crank position, but as of late....all that has suddenly stopped and the Truck starts Fine...........im sure it will act up again ...........as in previous times when ive decided to take her down to a mechanic ....she wont act up...but once home....she starts with the BS again ...lol
Old 01-09-2010, 07:04 PM
roadrunner2 roadrunner2 is offline
Robby,
j cAT makes a good point there.
Unless you enjoy problems, I'd kindly suggest you do as he suggested.
If there IS a wire (periodically) touching the ignition it may have swung out of the way temporarily, waiting for the chance to go back.
The problem with doing nothing is not knowing when you're finished.
Tags
ignition , problem , starter , tahoe
