Old 07-22-2004, 06:48 PM
94XJ 94XJ is offline
94 XJ VERY slow cranking
Please help!!!
Starting has gotten more and more difficult over the past few weeks (sounds like the oil is REALLY thick). Battery replaced today -- no help. Oil changed -- no help (it's leaking but then the mechanic stripped the threads on the drain screw -- Argh). It was a quart low which bothers me because I check it regularly.
I read something about bad oil senders? Could mine be out and there's no oil getting to parts of the engine and I'm slowing burning it up? I do get a wierd awful buring smell most of the time now that smells like burning rubber or burning oily gaskets.
Someone said check the starter but would that cause the ultra-slow craking (like no more that one full turn over per 10 sec.?).
Anyone able to assist?
Cheers
Old 07-22-2004, 07:03 PM
Dale Aeppli Dale Aeppli is offline
Re: 94 XJ VERY slow cranking
Originally Posted by 94XJ
Please help!!!
Cheers
HI, IT SOUNDSLIKE YOU MAY HAVE A STARTER GOING BAD, PROBABLY THE END BUSHINGS ARE BAD MAKING THE STARTER DRAG, IF THAT IS IT REPLACEMENT IS DUE DALE [email protected]
