Old 08-19-2004, 09:11 AM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
Question slow cranking, sometimes?
I have a 92 K1500 5.0L 5sp w/ 184k mi on it. Sometimes the engine will crank just fine, and sometimes the engine will turn over slow ( like with a low battery). It happens with the motor hot or cold. I have changed the battery with the correct cranking amps, and the neg. battey cable. I'm figuring its the starter, or could there be something else I should look at. I appreciate any help before i buy a new starter. Thanks.
Old 08-19-2004, 01:57 PM
rpreston rpreston is offline
Re: slow cranking, sometimes?
You could verify the alternator is charging the battery correctly. Should be charging at about 14+ volts. Wouldn't be surprised if the starter was bad. I've got a little over 110K on my 1990 and I've had to replace it twice.
[SIZE=3]"How do you feel about Women's rights?" " I like either side of them."[/size] - Groucho Marx
Old 08-19-2004, 05:54 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
May even be a starter solenoid. But do what preston said first.
Old 08-20-2004, 12:33 AM
TweakedGM TweakedGM is offline
if you r going to get a different starter,get a PG260 starter it is a smaller one cost bit more.Or just oil the brushings , change the brushes, clean the armature,check the drive and forks and check your soleniod and way you go.
Old 08-20-2004, 10:51 AM
joe92k1500's Avatar
I checked the alternator, and it's puting out over 14V. I'll play with the starter and solenoid this weekend, and post how it goes. Thanks for your insight.
Old 08-21-2004, 10:33 PM
joe92k1500's Avatar
Fixed it!!
Replaced the starter today, with a new one. Works better that when i bought it. Thanks for the advice! Now i'm goin to relax.
