Old 10-08-2003, 01:22 PM
Kenny Rogers Kenny Rogers is offline
Rotor replacement question
I have read that when replacing brake rotors, use of a C-clamp to squeeze the piston into the caliper makes it easier to fit the caliper & pads over the rotor. I have also heard that in doing this, the ABS system can get damaged.
My rotors vibrate badly during braking, so I am replacing the rotors & pads. I am not sure how to correctly fit the caliper & pads over the new rotors (it's a tight squeeze!). Is there a correct way?
Thanks in advance,
Ken R.
Old 10-08-2003, 08:33 PM
RidgeRunner RidgeRunner is offline
Send a message via ICQ to RidgeRunner Send a message via AIM to RidgeRunner
Re: Rotor replacement question
I've never heard such about the ABS system potentially being damaged by a C clamp. That's what I've always done on mine.
Old 02-21-2004, 10:59 AM
fr0stbyte fr0stbyte is offline
Yes you can do this.. I don't know about damaging the ABS or not.. (Have done it this way several times before on my other Cavs with no ill effects) but I would sugest loosening the bleeder valve a little bit to allow fluid to escape while doing this.. You need to bleed your brakes afterwards.. but then again that should be done any how..
Just be sure not to push the piston back any farther then being flush with the caliper.. (not sure if it's possible to push it 'too far' back)..
02 Santa Fe Rear Rotors, replace 1 or both? mkenyon2 MY 01-06 1 03-12-2010 08:23 PM
Front Brake Job - Replace Rotors? buickultra2000 Park Avenue 3 02-09-2010 07:11 PM
Cap and Rotor Replacement Question Clay Heinz Jetta/Vento/Bora 4 04-06-2004 02:29 PM
Rotor Replacement urasula Maintenance 8 09-10-2002 03:19 AM
Rotor replacement questions? Cap Integra 6 04-30-2002 10:06 AM
