Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 10-04-2003, 04:21 PM
95AvengerEs 95AvengerEs is offline
Unhappy Can Someone Please Help?
I just bought my avenger 2 days ago and i have a problem. The check engine light came on today while driving the car on a rough road then the transmittion started acting up either when you gave it gas it would just rev up like it wasn't in drive or it would stay in 2nd gear and not shift.But if you stop the car and shut it off and waite about 5 seconds then start it again it would shift perfect.Would and sensor cause this problem? Or is my tranny shot? PLEASE HELP!!
Old 12-19-2003, 04:50 PM
jay6g73 jay6g73 is offline
heh mines in the shop for that now...
what my problem was the solenoids on the A604 are external so debris built up and ended up in the transmission... ur tranny is shot, $1200+ for my repairs
Old 05-09-2005, 12:20 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
There's a possibility that you've got a pump out. There's a pump that forces Transmission fluid into the mechs that shift your gears. If that pump goes out then you can't shift. I had another car that was doing the same thing for me. Have it checked out.
Old 05-10-2005, 11:09 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Can Someone Please Help?
Or you could be suffering from the #1 cause of transmission issues with Chrysler A-604 transmissions, you have the wrong transmission fluid in. Drain it out and run yourself some Mopar ATF+4 in your transmission. I'm 95% sure that will clear up your problem, if not it could be a bad solenoid pack, or even the TCM might need to be flash programmed.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 05-11-2005, 08:09 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
If you put the wrong fluid in any transmission it will do that.
My Mopars
Old 05-11-2005, 10:02 PM
you are very correct, but Chrysler's are very picky about what kind of fluid you run in them, more picky than GMs or Fords or any other manufacturer out there.
can someone please help me fix my heater Redline_civic91 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 10-10-2003 10:10 AM
Can Someone please help me davehewitsonuk Graphic Manipulation 3 12-07-2002 09:16 AM
Can someone please help??? integra818 Car Modeling 12 11-02-2002 10:17 AM
Can someone PLEASE help ME? kiang Integra 3 10-02-2002 12:43 AM
can someone please help me?!?!?!? slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-04-2002 10:25 PM
