Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-01-2003, 12:41 AM
Auto_newb Auto_newb is offline
Wet system? Dry system?
What do these mean? I don't get it!
Old 10-01-2003, 08:26 PM
SaabJohan SaabJohan is offline
Re: Wet system? Dry system?
Depends on what you talk about. Most common to talk about wet and dry systems are probably clutches, nitrous injection and lubrication systems.
Old 10-03-2003, 12:07 AM
Leahcim Leahcim is offline
Send a message via AIM to Leahcim
If your referring to N20 then...
Wet System - When nitrus is combined with fuel is the throttle body before it is taken in by the engine
Dry System - When nitrus is injected in itself through the air intake and fuel is pumped in seperetly
The only real diffrence between how you do it depends on how you tune it. You have to be sure to get the right combonation of Fuel/Nitrus otherwise it could burn too hot or be more prone to detonation or other issues.
If at first you don't succeed, try again. If you don't succeed then, destroy all evidence you tried.
Old 10-03-2003, 09:12 AM
Yeah I was referring to N2O.
So a wet system is when N2o is injected with the fuel ? A dry system is when N2o replaces air ?
Old 10-03-2003, 06:52 PM
Re: Re: Wet system? Dry system?
No, a dry system adds N2O to the intake air and the extra fuel needed is injected separatly, for example by increasing the fuel pressure in an fuel injected car.
Old 10-21-2003, 02:42 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
A dry nitrous sytems is when you are spraying nitrous into the car but no addition fuel lines have been added to spray in more gas. You will get the extra gas through overdriving you injectors and pump.
A wet system will spray nitrous and fuel through an additional line usually through the intake unless it is a fogger system.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-23-2003, 08:40 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
A dry system is safer to run for the beginner, because it's less involved.
A wet system is more advanced and caution should be used in a wet system. A wet system that is not tuned correctly can result in dangerous happenings. Say in a nitrous backfire, where timing was off, fuel supply was not adequate, causing detonation. Take a look at this.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
What is the difference btw wet and dry nitrous systems? ToP cAt Forced Induction 6 03-14-2004 10:31 AM
Nos Wet System Or dry System Diference?? Number4 Performance 8 10-25-2003 07:19 PM
Nitrous: Wet Vs. Dry b16rex '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-14-2003 04:27 AM
Wet Or Dry? BLU CIVIC Forced Induction 2 02-10-2003 01:44 PM
NOS wet vs dry pist Engine 0 09-24-2001 02:22 AM
