Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 07-28-2003, 05:15 AM
Number4 Number4 is offline
Nos Wet System Or dry System Diference??
Whats the diference between a Nos Dry System and Wet System which 1 would b a better pick
(Not that im gettin Nos )
Old 07-28-2003, 12:23 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
A dry system sprays just NOS into the manifold or other intake parts, while a wet system uses a twin nozzle set up and inject fuel along with NOS. The wet system will always be able to produce more power reliably. It also does not have to rely on your current fuel supply system to over come the lack of fuel delivery.
Dry systems are generally cheaper in price also.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 08-07-2003, 03:01 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
the problem with wet systems is that you'll run leaner in cylinders closer to the intake and progresivelly richer in the other ones.....
there are some very good dry systems out there that will make sure you never lean out and you'll have a uniform mix in all cyl.....the best dry system by far is the venom 2000....a bit pricy though
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 08-07-2003, 06:33 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
It depends on the intake design. For the RB26, you are right.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-14-2003, 09:12 AM
sKyLiNe_69 sKyLiNe_69 is offline
Send a message via Yahoo to sKyLiNe_69
Direct port baby!! lol
Old 08-19-2003, 08:33 PM
ZZII's Avatar
ZZII ZZII is offline
I say go for a wet system for the RB. think about it. the cylinders are totally vertical! just spraying it in the manifold won't do too much, as compared with mixing it in with the fuel.
Old 08-20-2003, 12:23 AM
SkylineUSA's Avatar
It si not the cylinder placement that is the problem, its the intake design. A wet system or a dry system will blow the #6 cylinder. Thats why if you put new injectors in your RB26 you shold always put the best flowing in #6.
Old 09-15-2003, 05:12 PM
1_revin_Silvia 1_revin_Silvia is offline
Send a message via ICQ to 1_revin_Silvia Send a message via MSN to 1_revin_Silvia
if you absolutely want to do nitrous do it right the first time and go with direct port. it takes more knowledge and time but it's the safest I think. If I were you tho and I had an RB26DETT I wouldnt put nitrous on it because one problem happens and then you're out 7000.00...Just turbo upgrade the fu#k out of it and you will smoke anyone with nitrous or not! Imagine...No spray and you still smoke a guy shooting his spray hehehe, his face in the rear view mirror would look very satisfying
-Justin
RB26DETT swap into my 240sx S14 journal: http://www.cardomain.com/ride/2343921
Old 10-25-2003, 07:19 PM
tyndago tyndago is offline
Send a message via AIM to tyndago
Re: Nos Wet System Or dry System Diference??
1 R33 GT-R . Stock motor , stock cams , stock headgasket , stock exhaust manifolds , stock maf meters , stock bov , 2530 turbo upgrade (under manifold bolt on) . Direct port nitrous .
10.8@132 , 10.9@129 , 10.7@137 .....
Any questions ?
Quickest GT-R in the world - on street tires has a T88 and Nitrous..... Croydon Wholesalers - New Zealand 8.55@165 mph.
Sean Morris
http://www.2009gtr.com
http://www.gtrusablog.com
