Old 08-13-2003, 09:39 PM
b16rex b16rex is offline
Send a message via MSN to b16rex Send a message via Yahoo to b16rex
Nitrous: Wet Vs. Dry
what's a better nitrous set up? What's the difference between the two? I've heard amateurs shouldn't use wet and stick to dry, is this true, why? Thanks for the help
-1994 Civic coupe DX
Old 08-13-2003, 10:03 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
I dont know your answer, but try to do a search on this, it seems like this was brought up like last week or something.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-13-2003, 10:09 PM
Bustamon's Avatar
Bustamon Bustamon is offline
If you use a wet nitrous system it would be best to use it Direct Port. The dry system would work best through the common way which is running it through you intake. It is possible to use the wet kit through the intake but there will be some wear and tear damage done to a stock engine if you go that route. Your best bet for a begining system is a simple dry set-up. Just my two cents.
Old 08-14-2003, 03:09 AM
91civicDXdude's Avatar
a dry nitrous sytem is asking to blow the shit out of your engine. adding nitrous without adding extra fuel is stupid and lazy.
go wet all the way.
Old 08-14-2003, 04:27 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Dry: Blowback through a mis/back-fire can be a real issue. Wet is more finicky to set up but the better route.
Better still... get a turbo or go all-motor with no steroids - more kudos that way
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
