Old 09-29-2003, 03:22 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Another Idle question...
After I run my car for a while, when I stop at a stop sign or even just have the car in neutral, the idle will be way up at 1,500 then drop off to like 800 then go right back up to 1,500 and keep doing it over and over. Also, on another topic, after my car sits for a while (turned off) it cranks a while when I try to start it, like it needs to build up fuel pressure. Do you think im losing fuel pressure when its turned off? Something wrong with the pump maybe?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-29-2003, 04:02 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
well for your starting problems, thats your main relay going out, replace that and you'll be fine.
as far as the revving, id say its your TPS sensor in your dizzy, the whole dizzy needs to be replaced cuz honda doesnt sell those seperatly.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-29-2003, 05:40 PM
Im sure you meant the throttle body not the dizzy but yea, that might be it. But I thought that either the main relay worked or it didnt, I didnt know it could be "going bad". Im gonna check that fuel pressure thing tomorrow though. Thanks for the reply
ZC stuff
Old 09-29-2003, 06:35 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
TPS or also the Fast Idle Valve, but I'm going with TPS on this one. Fuel pressure: if it was an issue then the engine wouldn't start - always check the electricals before the mechanicals. It's usually electrical that gives out.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 09-29-2003, 07:53 PM
tylercrx tylercrx is offline
Arrow
i have the same problem and im pretty sure its the EACV or TPS. anyways, where could we buy a TPS and where is this sensor located in the car? thanks.
Old 10-19-2003, 11:11 PM
tylertime tylertime is offline
ok the tps is semi-perminently screwed right to the drivers side of the TB. it shouldn't really be removed!! you need to get a whole new TB and stick it on. eacv is directlky behind the TB. those can be replaced and or adjusted/cleaned up.
Old 02-18-2004, 11:06 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
Re: Another Idle question...
hey 91civichatch2571, did you ever fix those problems? mine is having those exact problems, the idle surging and the cranking a while just to start. so what did you do?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 02-19-2004, 12:27 AM
Re: Re: Another Idle question...
Changed throttle bodies, im pretty sure it was the tps. never figured out the fuel problem though, it seemed to just work itself out over time. wierd...
ZC stuff
Old 02-19-2004, 12:36 AM
Setanta's Avatar
Definitely the TPS then
'99 PY DC2R
'85 BBS BMW E30
Old 02-19-2004, 09:00 AM
Jay eS Iye's Avatar
so should i look for a new TB or can i change out the TPS? also, are there any TB's i can use from other cars that would be any better?
Another Idle question blk_srt Off-Topic 5 12-11-2005 09:36 AM
another high idle question w31770 F Series 8 07-12-2005 10:20 PM
Another Idle Thread! TreStringz Integra 7 04-19-2005 06:32 PM
another idle tampa Escort 7 04-04-2005 08:48 AM
Another idle issue thread 1991 Sport 4.0 ops5 Cherokee 3 03-04-2005 01:45 PM
