| Off-Topic Talk about anything other than cars. |
I've had a problem with the idle on my car since I bought it and I've tested everything from vacuum leaks to injectors and everything but I just go to thinking could it possibly be that the hunny comb is removed from my mas? I wasn't the one to do it, the car came that way. just a thought.
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Re: Another Idle question
Removing the honeycomb on a 2g MAS is a no-no. Have you checked your TPS?
now - 2000 civic soon - 2002 is300
Deffinately if the honeycomb was removed it would act like that. Also if that's not the case, I initially had a problem with my throttle body not closing all the way, causing it to idle high after warming up. To fix this I cleaned the carbon out of it and added another spring on the throttle to help close it with more force. Good luck.
95 Talon Tsi AWD 5spd 2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Re: Re: Another Idle question
Call me stupid, but what is the honeycomb??
![]() ![]() 1998 RS 5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs. |
I agree that removing the honeycomb will bollix the idle. On a 2g with the side and lower HCs removed you typically need a 30-35% positive adjustment on the AFC to correct it. That's one third, pretty significant 2Gs should always have all the honey combs in, since they are good up to 50 lbs/min. If you are going over that a properly hacked MAS can provide an additional 7 lbs of capacity (14%), and with DSMlink it can run very close to stock with the settings for the MAF comp table they provide.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
