Old 09-26-2003, 08:05 AM
pmarque pmarque is offline
Acrylic Paints
How to use acrylic paints? Is there any special preparation or just open the can and paint directly into the kit?
Thanks
pmarque
Old 09-26-2003, 08:06 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: Acrylic Paints
Acrylics don't really look good when you brush them on. Otherwise, you just paint it right on from the can, after you primer it.
Old 09-26-2003, 10:58 AM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Re: Acrylic Paints
Thanks
pmarque
Are you airbrushing or handbrushing? Handbrushing you can use it straight out of the bottle. Airbrushing requires thinning of the paint.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 09-26-2003, 11:18 AM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
If you are handbrushing, and using water-based acrylic paints, such as Tamiya, you have to shake it first to mix the water with the paint.
-Henry-
Old 09-26-2003, 11:34 AM
Murray Kish Murray Kish is offline
Getting Old...
Re: Acrylic Paints
This is all probably in the FAQ, but I'll add my $.02..
- if you're brush painting, they can go on right out of the jar. However you might find that they go on a little smoother if you just add a tiny bit of thinner (ie. about 10%).
- if you're airbrushing, they must be thinned with either the manufacturer's thinner (likely sold at the same place you bought the paint) or with something like alcohol, windex, etc. You'll have to experiment with the ratios, but anything from 10% to 50% thinner could be used.
Good luck!!
Murray
Old 09-27-2003, 12:23 AM
chaos's Avatar
chaos chaos is offline
AF Premium User
I found brush painting a lot easier with the part primered a bit.
Old 09-27-2003, 01:16 AM
LaTtE`X LaTtE`X is offline
Send a message via Yahoo to LaTtE`X
Re: Acrylic Paints
Primering usually makes the acrylic adhere better when air brushing.
I got the fever for the flava of the cootchie
Hot Action Cop
Fever for the Flava
Superkala / OST Smallville / OST Need For Speed-Hot Pursuit 2
Old 09-27-2003, 04:38 AM
primera man's Avatar
"P-Man"
Re: Acrylic Paints
Warm the paint in hot water also to help it flow better when brushing
View All My Models Here.
is Tamiya rubbing/polish compound only for acrylic paint jobs? dgdarien Car Modeling 13 06-25-2007 02:10 AM
Acrylic Paint Question JE123 Car Modeling 14 06-24-2003 04:41 PM
Primer for Acrylic Paints Deejay27 Car Modeling 9 04-03-2003 03:59 PM
Tamiya Acrylic Paint *NOT* mini djmr2 Car Modeling 6 08-17-2002 03:55 AM
Getting acrylic paint off clear parts Noz Car Modeling 10 05-15-2002 09:08 AM
