Old 09-23-2003, 11:05 PM
tball tball is offline
94 Cav. engine stalling
My 94 cav. has a problem. Most of the time it happens when I am coming up the pff ramp from the interstate. If I apply my brakes nice and evenly and slow down at a steady rate, then it is fine, but if I let the car coast and apply my brakes mainly at the top of the ramp, then it will die. It will start right back up afer a 30 to 45 sec. interval. It also seems to run rough (missing) when I first start it up in the mornings. If I give it a little gas, I can feel the miss become less and less, and after about 5 or so sec. it stops missing and runs just fine (except for the above problem) Any ideas?
Old 09-26-2003, 12:09 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
Take it to Autozone and have them run if for codes. It's free and just takes a couple of minutes. You may need your fuel injectors cleaned or something. Maybe you're fuel filter needs replaced. There's any number of things that could cause it, but instead of randomly replacing things, get the codes from your car's computer and fix it from there. HTH
Old 10-21-2003, 08:34 PM
shhtbyrd shhtbyrd is offline
try checking your idle air control valve
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 09:42 PM
95 Cav Z24 stalling when hot Chels921 Cavalier Problem Diagnosis 0 11-04-2006 07:37 PM
95 Cav Z24 stalling when hot Chels921 Cavalier Problem Diagnosis 0 11-04-2006 07:36 PM
91 Cav automatic stalling at stops mikey725 Cavalier 7 05-29-2004 09:28 PM
85 Cav Conv. stalling when I stop Sheba Cavalier 6 04-08-2004 10:35 PM
