Old 05-24-2004, 02:34 PM
mikey725 mikey725 is offline
91 Cav automatic stalling at stops
This seems like a common problem with older cavs:
After driving my 91 cav with an automatic transmission for 15 - 20 minutes (when the car has warmed up), it stalls at every stop on the downshift. I can usually nurse it home at this point as long as I manually downshift at stops. It doesn't seem to have any problem upshifting during acceleration at this time. I've tuned it up (cap, wires, rotor, plugs, filters), changed the engine and transmission oil, and had the starter replaced over the past winter. The car is running great except for this stalling problem.
Most people seem to think the problem is the Torque Converter Clutch Solenoid; however my local service shop suggests I get a new transmission. My questions are as follows: What does this part do, how difficult is it to swap this part out, and how long can you drive with it simply disconnected?
thanks,
MAH
Old 05-25-2004, 08:25 AM
marchi1's Avatar
marchi1 marchi1 is offline
Send a message via MSN to marchi1 Send a message via Yahoo to marchi1
Re: 91 Cav automatic stalling at stops
Sounds like what mine did, and it is probably the torque convertor clutch solenoid. it isn't hard to do, just time consuming, and I did mine myself. Took me a couple of hours, but was also taking my time, and trying not to remove all the closouts and such....
Old 05-25-2004, 09:08 AM
doormouse1058 doormouse1058 is offline
Send a message via AIM to doormouse1058
where is the Torque Converter Clutch Solenoid? and how much does it cost to replace?
Old 05-25-2004, 02:01 PM
So far so good. I unplugged the TCC and drove around a bit last night with no stalling. the car seems to run rougher though. If I can avoid it, I'd rather not replace the TCC as I'll be selling the car in a couple of months. Does anyone know how if having the TCC disconnected will hurt the transmission??? I'm planning on driving a bit in the near future and don't want to wreck the tranny.
Old 05-26-2004, 02:02 AM
matt919's Avatar
matt919 matt919 is offline
Send a message via AIM to matt919
Having the TCC disconnected will not hurt the transmission. The TCC's job is to lock the transmission in the highest gear for fuel economy. It shouldn't effect the cars driving, or anything else. The only minor effect, is losing maybe a mile per gallon of fuel economy.. and mostly only on highway driving.
Old 05-28-2004, 07:27 AM
ebritt's Avatar
ebritt ebritt is offline
the tcc doesent lock the tranny into hi gear, but locke the converter and makes a physical connection from the engine to the tranny. this makes for less power being lost due to slippage from a fluid connection only.
Old 05-28-2004, 03:16 PM
public's Avatar
public public is offline
Yes you can leave it disconnected. I have a 94 that has been disconnected for a number of years now. I can barely notice the change in gas mileage. good luck.
Old 05-29-2004, 09:28 PM
anaytato anaytato is offline
Re: Re: 91 Cav automatic stalling at stops
u can run it with it out dont worry about it it wont hurt it .
