Old 09-22-2003, 05:33 PM
granguzs granguzs is offline
Send a message via MSN to granguzs
Talking Brakes stop working
PLEASE SOMEBODY HELP ME!! THE BRAKES ON MY 93 GRAND CARAVAN STOP WORKING, THE ABS LIGTHS ARE ON, I CHECKED ALL FUSES AND THEY LOOK OK, I ALSO CHECKED THE RELAY, ANY SUGESTION?? I WILL APRECIATTE VERY MUCH
Old 10-18-2003, 12:44 AM
kizon kizon is offline
Same thing happened on my Grand Caravan I ran a stop sign because of it. It was a good thing nothing was coming. A part in the brake system is on recall for the longest time. I went to the local Dodge dealership and luckily they took it in and fixed it for free.
Old 11-18-2003, 10:12 AM
yale329 yale329 is offline
Re: Brakes stop working
Hope you fixed it by now. If not, check your master cylinder to see if it's extremly wet. Total brake failure is very unusal.
Old 11-18-2003, 11:18 PM
Re: Re: Brakes stop working
i,ve heard that abs brakes on caravans give a lot of problems. my brakes works but i have to press the pedal very hard, i think the pump doesnt work, i want to change the whole unit for a regular unit, w/o abs.those anybody knows if this is possible? i have a bendix 10 system and want to change it for a regular system (vaccum system)
Old 12-26-2003, 09:29 PM
davidanddelo davidanddelo is offline
Total brake failure
I have also personally experienced total brake failure on my '93 minivan. As one of the other respondents has said, if you push REALLY hard, the brakes are still there.
I am about to raise some hell at the dealer as this has been "fixed" once before. I'm beginning to believe that there may not be a fix (only a change to another brake system).
It has happened about a half-dozen times over the past 3 or 4 years I've owned the car. Both the ABS and the Brake light come on suddenly without warning (sometimes I'm not even touching the brake). After the lights are on, I still have a few power assisted pushes left. The really weird thing is that it continues to "fix" itself. When it does, the boost (ABS) motor runs for a good 30 seconds to get the vacuum back up.
Old 12-08-2005, 12:25 PM
azakram azakram is offline
Check all tires for any oil leak, some time break cylinder leaks and it causes total break loss. Happen to me.
ABS is a problem and it is not going away although I have fixed all the breaks.
Old 12-10-2005, 07:24 PM
Alexandra Spears Alexandra Spears is offline
At one point I was having issues with low brake fluid in my master cylinder, turned out to be a leaking rear wheel cylinder. The shop caught it when I was getting my front brakes done.
Don't blame me, I voted for Peroutka!
Constitution Party
96, I heard a pop under the hood & my brakes stopped working cogar7 Aurora 5 09-09-2021 09:55 AM
91 Ciera brakes WAAAY too sensitive vbettiga Cutlass Series 2 03-07-2009 01:57 PM
My brakes suddenly stopped working...o.0 Mic1980 Neon | Plymouth Neon 6 03-07-2007 10:39 PM
blinkers stop working when i step on the brake brendaa25 '91 - '96 3 06-30-2006 08:35 AM
1998 Chevy Blazer Brake Lights Stopped working. LndShrk Blazer 14 02-17-2006 10:06 PM
