Go Back   Automotive Forums Car Chat > Saturn > LS/LW
Old 09-21-2003, 12:16 PM
swzine swzine is offline
Send a message via AIM to swzine Send a message via Yahoo to swzine
2003 L200 Tighter Suspension
I have a 2003 L200 which I am very happy with. My only complaint is the handling. The car is a little too bouncy and doesn't feel natural around turns on the highway. What is the best way to improve the handling? APC makes a coilover kit for the L200 - APC651090. Has anyone had experience with this kit or any other kit? Basically I wish the car was a little lower and tighter. Would this accomplish that?
Old 10-03-2003, 05:46 PM
socketz socketz is offline
The L200 has lower rate springs and different valving on the struts as compared to the V-6.
Progress makes some stiffer springs that will fit your car while affording you about a 1.5 inch drop:
http://www.progressauto.com/
Old 10-16-2003, 05:59 PM
THEDAVIDMAN THEDAVIDMAN is offline
Re: 2003 L200 Tighter Suspension
[quote=swzine]I have a 2003 L200 which I am very happy with.
Hey bro I just got into a 2003 L200 myself. Did yours come with the Sport package? I couldn't resist as 2003 has brought some SAAB lines into the bodywork.
I found a suspension shop if you dont have the grand for springs and struts, that will give you a minor drop (about 1 inch) by just cutting the stock springs. A big caution if you consider this, is how they cut the spring.
If done with a torch then compression rates can be lost as the tempering is lost.
The shop I found will do it with a High rpm diamond blade and a constant flow of cold oil to keep the heat down.
The pitched advantage besides saving cost is that the stock dampners which are compression adjusted will be slightly stiffer for being 1 inch lower.
Even a 1 inch drop requires the rear bumber stops to be shaved a bit.
The other advantage to a one inch drop only is that you don't compromise any front end geometry with such a mild drop. (No
no torsion roll or flutter or excessive wear on the trans-axles, bushings)
How do you like the factory skirting? I also am very happy with this ride.
Pases in fifth gear with passengers no problem.
I plan to add the K&N filter, tornado fuel saver soon. I have already made a minor fuel timing adjustment through ohm-load adjustment on the intake air sensor circuit. Definitely a little more pick-up and no low end torque loss. Anything more than 3-4 ohms resulted in a loss of power. I should also have 2 1/4 inch piping from the down pipe to the exhaust tip soon. Looking for about 8-10 hp with that mod.
I did want to get it up around 170-180hp at the fly wheel but parts for power modding the 2.2 / L200 are no where to be found.
Considering 8-10 lbs boost. www.Twistecproducts.com
And of course the tunes are bad ass with that sub-woofer and power amp.
Let us know what you do man. I am sure there are more L200 owners who would love to push some serious air through the motor. I am one of them.
TheDavidMan.
2003 L200 won't start and stuck in park mike maurin LS/LW 3 08-12-2009 09:12 AM
2003 L200 with water on the carpet b.preston LS/LW 2 12-02-2008 03:48 PM
2003 L200 radio not working after battery change b.preston LS/LW 1 08-06-2008 10:50 PM
2003 L200 Hard Shifting donrichrules LS/LW 1 03-27-2007 10:53 PM
2003 ford mustang suspension problems sjlawr Ranger | Courier 2 04-20-2004 10:20 PM
