Old 09-08-2003, 02:59 AM
hondatool hondatool is offline
coolant disappearing???
alright...everytime i fill up my coolant resevoir...its gone in about 2-3 days...my engine temp stays normal...i dont overheat...i checked for leaks...none...where is it going?...is the radiator bad?...i have no idea what to do next?..pressure test?..how?
Old 09-08-2003, 11:20 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
If the coolant isn't dripping/leaking from anywhere, and the hoses and radiator appear ok, then I would guess head gasket. They normally wear out as they get old or with many miles, and it leaks coolant into the cylinder, which burns, so you won't see coolant leaking, but you will be loosing it.
Old 09-08-2003, 06:29 PM
michaelsd16c michaelsd16c is offline
Re: coolant disappearing???
Take it to a radiator shop. The put a special cap on the radiator to check the presure so see where the loss is.
Old 09-08-2003, 11:47 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Odd, mine does the same thing. No leaks that I know of or can tell, radiator fluid is still at the top, but the reservoir dissapears after a few days. If the reservoir only connects the radiator, and the radiator stays full at the top, wouldn't it suck some of the radiator fluid out if it was a gasket issue? Seems like common sense there to me unless I'm missing something.... Also I doubt it's a gasket with me anyways since I only have 31k miles on my car, and my temp never overheats either.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 09-09-2003, 02:05 AM
Plasmex Plasmex is offline
Send a message via AIM to Plasmex
I had the same problem
I was having coolant disapearing...
I would drive around normal and nothing would happen.. No leaks i could see.
If i drove around high reving 8-9kpms (getting my engine really hot and really pumping the fluid through the hoses)
I could get out my car and go eat lunch.. come back and have about a 6 inch green puddle under my car but when i went and looked for it I couldnt find anyleaks.
So instead of turning off my car After high reving
I would leave the car running and open the hood and look for any sweet smells and drips.
Turns out my top radiator hose very close to the head had a tiny tiny crack in it, and it was leaking very very slowly onto my transmission,and when it would land on the transmission, it would evaporate.... reason being why there wasnt always a pool of green under my car.
Anyways check your radiator hoses while they are hot.
97 red honda civic lx sedan b16a w/ Type R head,full headwork Port and polished, ported intake manifold, 310cc RC injectors, ITR cams, Skunk2 adjstable camegears, VAFCII, modified apexi ws II exhaust
Old 09-10-2003, 04:19 AM
ill check that..thanks...so the best time would be after hard driving huh?...how much do radiator hoses cost to replace if it is that....yeah last thing i wanna do is check the head gasket...thats a bit of a pain in the ass...last resort check there...someone told me to take it to a radiator shop also..i gotta find one around here..any suggestions?
Old 09-10-2003, 08:31 AM
a single radiator hose will run ya about 6 bux at a part shop
95 bonne coolant disappears ksfdad Bonneville 7 11-07-2009 09:57 PM
Coolant disappearing Torqued Metro 2 09-17-2005 12:10 PM
Coolant disappearing from overflow reservoir. SonOfDolomite Windstar 1 02-14-2005 08:54 PM
Coolant disappearing? ashah000 Off-Topic 12 09-15-2004 09:31 PM
Coolant Disappearing dubes454 Cherokee 2 06-29-2004 07:20 AM
