Old 09-15-2004, 05:55 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Coolant disappearing?
Over the last few days I have been noticing that my coolant in the overflow tank has been getting lower and lower everyday. It lowers approx. a 1/2 inch a day. I dont have white smoke coming from the exhaust, and my temp gauge has not gone above the normal (half way) level. I don't see any coolant leaking on my garage floor.
Really dont know what could be causing this, and PLEASE dont tell me it is the headgasket.
Thanks!
For Sale 98 Eclipse GS, 5 spd
Old 09-15-2004, 06:21 PM
cbell77 cbell77 is offline
Re: Coolant disappearing?
hmmm maybe it is leaking lol i am sorry i had to say that. check if coolant is on your driveway.
1966 mustang for sale asking $7900 call 757-766-3702
Old 09-15-2004, 06:24 PM
ashah000's Avatar
Old 09-15-2004, 06:25 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If the exhaust is white, it's burning. I'd suspect the problem is leaking, though. It's either a radiator hose or a turbo hose.. you just have to look around. I've had to replace a turbo coolant line that was leaking at the crappy stock clamps, so look under the car if you can't see it from above.
Old 09-15-2004, 06:32 PM
ashah000's Avatar
I am NT, and there is no white smoke at all. The only thing I can think of is that the coolant is leaking somewhere and staying in the engine compartmant and not hitting the floor.
Old 09-15-2004, 06:47 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
it could be leaking only under pressure so when it doesnt run long in your garage you dont notice. park it in your driveway with a sheet of cardboard under it start er up and let it run for awhile then check if you see anything. if you cant find it buy a leak tester at autozone and pressurize the cooling system.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-15-2004, 07:03 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
did you check your oil? pull out your dipstick and look on that... if is a milky brown color, non transparent then thats where its leaking too.
Old 09-15-2004, 07:13 PM
joemathews's Avatar
joemathews joemathews is offline
(Jake uses a euphamism for "it's your headgasket")
But seriously, make sure your coolant cap is sealed tightly on the reservoir. If not it can evaporate, obviously. If you have any hole in your system, the coolant could be heating enough to evaporate.
1996 Eagle Talon
Old 09-15-2004, 08:08 PM
MrZ's Avatar
MrZ MrZ is offline
ashah000;
Check underneath the throttle body where the coolant hoses connect to it. What can happen is that the coolant drips out and collects on the top of the trans. When you're driving the fluid doesn't accumulate very much because of the car jostling around, wind blowing over the trans, etc. It may be that when you park the car the leak is slow enough that the litte bit of fluid that leaks after the car is shut off just stays on top of the trans. It will be pretty obvious if either of these connections has been leaking once you get down there with a flash light and look.
Mark
Old 09-15-2004, 08:09 PM
ashah000's Avatar
Oil is fine..
I will check the overflow cap, just wondering if there are any other places that can be loose or have a bad seal that would cause the coolant to evaporate.
Old 09-15-2004, 08:14 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
get that coolant pressure tester from an autozone or whatever. it may be your water pump like me
are there any squeaking sounds from any of the belts?
Old 09-15-2004, 08:18 PM
ashah000's Avatar
The PS belt but that has been squeakin for over a year, and it is pretty common.
How does the coolant pressure tester work?
Old 09-15-2004, 08:31 PM
http://www.automotiveforums.com/vbul....php?p=2246480
