Old 08-20-2003, 04:14 PM
ilacuss ilacuss is offline
CEL code 16 - how to fix?
My 90 std hatch is throwing code 16 - fuel injectors. When I drive to work in the morning the CEL comes on and when I turn off the car and try to restart it, it won't start. Just cranks and cranks. But if I wait a few hours for the car to cool down it will start fine and the light won't come on at all until the next morning.
what should I look for to fix this?
Will injector cleaner work at this point?
also I've been reading about he main relay in these cars, could that be it?
thanks for the helpd.
E
Old 08-20-2003, 09:56 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
itd be ur main relay
it better get me to wyoming
Old 12-16-2009, 01:57 AM
starbai starbai is offline
Re: CEL code 16 - how to fix?
I found this thread through an internet search.
My prelude just threw this code 16 as well.
I already replaced the Main Relay and I know it works beacuse I have another prelude and tried it in that car and it works fine.
Fuel Pump and fuel Filter were professionally replaced 2 weeks ago by the previous owner before I bought it.
Whats my next step?
Replace fuel injectors?
Thanks in advance for anyone that can offer any advice, also apologize for bumping such a rediculiously old thread.
Old 12-22-2009, 04:15 PM
DownToGround DownToGround is offline
i had the same problem in my 4 door, it ended up being the iat.. intake air temp sensor. you can test it with a ohm meter. un plug the sensor, it sits on top of the manifold , its white. dont quote me but i think it should read 1.2-4.8 ohms or so.. also quick cheat afterwarm the car up, you shut the car down, try pulling the ecu fuse for ten seconds then the car should start again..
Old 12-22-2009, 05:09 PM
inafogg inafogg is offline
this is a very old post best to start a new one
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
How to fix a "p1694" code????? 99XXXJ Cherokee 5 04-17-2009 08:16 AM
How To Check CEL CODE? 92IntegraGS '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 09-21-2005 11:39 PM
I have the codes - how do I fix??? buschwakker S-10 2 07-10-2005 02:28 PM
How to get the CEL code? x-tatik TrailBlazer | Trailblazer EXT 7 11-09-2004 11:12 AM
How to get CEL codes from 86 Monte Carlo Crim Monte Carlo 1 09-25-2003 06:58 PM
