Old 08-20-2003, 03:34 PM
Crusty Captain Crusty Captain is offline
AWD Question
How is the power ratio from the transmisson to each wheel?
III Jettas and Ventos RULE
Old 08-20-2003, 05:52 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
i think its a 60\40 split
1
Shift_BOOST
97 s14
Old 08-20-2003, 06:16 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
that is the split that i remeber.
Old 08-20-2003, 09:58 PM
kjewer1 kjewer1 is offline
AF - Advisor
All of the differentials are opn diffs. Some of the DSMs have a viscous lsd int he rear though (there will typically be a yellow sticker that says so on the drvivers side door jamb if you have it). The center diff is open, but has a viscous coupler on it. The front diff is open. What this means is power is split front to rear evenly until one set of wheels spin (its usally the fronts, since weight trasfers to the rear). When one set spins, it get the power. Once the center vicsous coupling (VC) heats up it locks up, and you get a 50/50 split. So its an open system until one end slips, then its split 50/50. There is no other "split" designed into the system. For example, some cars have the gear ratios for the front and rear slightly different to preload the center diff/coupler, but DSMs dont do this. Some people get the center diff or VC welded (or use a solid spool) to make the car 4x4. 50/50 all the time. While this helps traction, you'll need a stack of rear axles and transfer cases laying around to replace the ones you break
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-20-2003, 11:41 PM
95_GSX's Avatar
thankyou again for educating the ignorant.
Old 08-21-2003, 12:55 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Re: AWD Question
Actually , I think its orange. But yeah , the rest is correct. So far the only AWD car in the US with a variable torque split is the STi . I beleive even the Evo is still running 50/50 open diffs. The 22B (which we didn't get ) could go from 20/80 (F/R) to 60/40 (F/R) , it had the most adjustable center diff I've ever seen.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 08-21-2003, 04:04 PM
Gee Whiz
I really appreciate the response and that I got it cleared out that the rear wheels have some power.
awd question clipsekid99 Off-Topic 8 10-25-2004 06:14 PM
awd question Underground_Killah Engineering/ Technical 7 08-20-2004 01:36 PM
AWD Question guitarXgeek Off-Topic 4 06-09-2004 09:07 PM
POS RACING ---> joe's 1990 AWD question!!! 95eclipse-gsx Off-Topic 5 02-04-2004 08:15 PM
AWD question Darc Tangent '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 01-31-2004 11:27 AM
