Old 08-18-2004, 10:05 PM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
awd question
i was told that on awd cars (all wheel drive) that when you have to replace one tire (blown out, flat, etc) you must replace all four. is this true? and why?
Old 08-19-2004, 12:46 AM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
Re: awd question
Uh.....no. It wasn't the guy at the tire shop, was it?
Old 08-19-2004, 12:47 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: awd question
Its import to maintain the same rolling diameter across an axle so that the differential in the middle is not over stressed and subjected to excessive wear.
In a 2WD car this means the two drive wheels have to be the same size, and the two non driven wheels can be of a differnt size.
However an AWD has an extra differential between the two axle sets and on many AWD cars having just one tyre that is a differnt size can place extra strain on it, as the front tries wheels turn at a differnt speed to the back wheels.
Old 08-19-2004, 01:24 AM
Registered User
Re: awd question
nah, i don't believe a word any one at the tire shop says (even my cousin who's the manager) i was just told at the subaru dealership about it today when i was with my girl looking at cars
Old 08-19-2004, 01:56 AM
Re: awd question
Well, if Mr. Killah here is even that stupid (and he better not be!....ha ha just kidding) as to put tires on his car that differ THAT MUCH as to put undue stress and strain on his car, then he shouldn't be driving.
(EDIT: can't friggin' type!)
Old 08-19-2004, 04:52 AM
Moppie's Avatar
Master Connector
Re: Re: awd question
Not a bad thing,since you don't have some real technical knowledge to share it might be best if you didn't type anything.
Take a brand new tyre, and a badly worn tyre, measure the differnces in rolling diameter. It won't seem like a lot, but now work out the differnt speed each tyre will be rotating at say 100kph. Its easily enough that if you drive only a few hundred kms (say to and from work for a week) you can do serious damage to a differential.
Old 08-19-2004, 02:16 PM
Re: awd question
How badly worn?
Plus...what kind of differential are you using?
And, I did not enjoy that "no real technical knowledge" stab. I didn't insult you, so I would like it if you didn't insult me.
Personally, I've been working on cars since I was about 12. I've developed my "technical knowledge" in the real world, not yet in a classroom (but it's in my five-year plan).
I don't want to argue, and I'm sure what I said above doesn't help the situation, but I wanted to get that out there.
To finish my wanderings off, I just want to say that in my experience of working on shitty cars where the tires aren't the same rolling diameter between the four tires, none of them have had a worn out differential because of it.
Thanks for your time...
Old 08-20-2004, 01:36 PM
Ground Rat's Avatar
Ground Rat Ground Rat is offline
Send a message via AIM to Ground Rat
Re: awd question
You won't hurt anything if you just replace that one tire.
'87 Turbo Sprint
'90 Turbo Voyager
'92 Typhoon #591
