Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-17-2003, 05:41 PM
Revolution 7o7 Revolution 7o7 is offline
Drivers Side Axle PRoblem
hey again nobody seemed to respond to my last problem i have 94 prelude vtec and i cant seem to get the drivers side axle out of the tranny ..Does it come out right by the tranny housing or is it like a three piece axle or something or am i just stupid ... i got the passenger side out but the driverside looks different where do i start thank you all very much ????? NEED ADVICE ??
Old 08-18-2003, 06:09 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
the stub axle attaches to the hub at one end and an intermediate shaft on the other for the left side
if you're not sure, get a manual or someone more experienced.
it's rather simple, as you just insert a flathead screwdriver in between the cv joint and intermediate shaft and pry the two apart, as they're held together with a ring clip on the stub axle.
if you cant figure out where the two meet, unbolt the intermediate shaft's support bracket, and separate the mid shaft from the diff instead. you MAY have enough play in the cv joint to do this, and then again, you may not.
Old 08-18-2003, 10:59 AM
Hey man thats for ur help that helps out a lot but now i have to get a whole new drivers exle b/ec i pulled the c/v join a part do u know it the drivers side axle will come with a new intermediate shaft or what ???thanx again
Drivers side axle shaft help? cadman20 Grand Prix 1 02-14-2009 04:55 PM
97 caravan driver side axle seal jhettel Caravan | Voyager 0 03-15-2008 10:06 PM
need help with removal of drivers side axle signtech909 Sephia 1 10-21-2007 05:17 PM
Help pulling drivers side axle growe58 Neon | Plymouth Neon 1 04-08-2005 12:33 PM
Drivers side axle dereks civic Escort 4 02-22-2005 07:40 AM
