Old 08-11-2003, 03:40 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
type r water pump
anybody know if i can use a type r water pump on my b18a? also will a b16a header fit and wats the difference between the b18a header and the b16a?
As American As A Burrito!
USDM 4 life!
Old 08-11-2003, 05:00 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
#1 Why would you bother??????? It's not as if it runs a higher peak-flow or anything.
#2 Yes and "not much". A B18C5 is very different however and requires some chopping into your front crossmember to fit in a 4G. Reason being 4 long primaries (?) in a 2x2 config - off the top of my head - I know they are a pain to fit.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-11-2003, 05:22 PM
well i was thinking about replacing my waterpump before i put my engine in, and my brother had an type r waterpump so i was just wondering if its the same, i would use a b18a waterpump if i had one.
also same reason for the header question i dont have one but my brother had a b16 header, but i think ill just buy a dc 4-2-1.
USDM 4 life!
Lesabre closed impeller type water pump source needed... scederas LeSabre 2 11-28-2010 11:24 AM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
