Old 08-03-2003, 06:53 AM
ah789454 ah789454 is offline
buzzin noise cumn from speakers
ive got a audio system in the car and theres a buzzing noise every time i accelerate.
the noise is in sync with the engine
wot is it and how do i get rid of it
thanks
Old 08-03-2003, 09:53 AM
KamiKaze Accord's Avatar
KamiKaze Accord KamiKaze Accord is offline
Send a message via AIM to KamiKaze Accord
i dont know how to fix that, but my friends talon has the same problem. Before the music comes on its a faint zzzz and when you hit the gas it gets louder, depending on your speed. The only solution we found was to play the music loud enough that it covers the buzzing up.
10% Tint All Around, OEM Spoiler, JL Audio XR Components, JL Audio 300/4, 2 JL Audio 12W7s, 2 JL Audio 1000/1s, Optima Yellow Top, 200a HO Alternator, Metra Dash Kit, Stinger 0ga Wiring Kit, Stinger Terminals, Stinger Fuse Holder, 2 Stinger 1.0 Farad Capacitors, Pioneer AVH-P6500DVD 6.5" Indash Touchscreen DVD Player, Playstation 2, Escort 8500
Old 08-03-2003, 01:44 PM
AirAllen01's Avatar
AirAllen01 AirAllen01 is offline
Send a message via Yahoo to AirAllen01
It's called engine noise, which is coming in through the wiring. I don't know how to fix it, just check your wires. Some of the more professional audio experts here will be able to answer the question of how to fix it. If you don't get any posts here, then pm Paul D, the moderator, he seems to know what he's talking about.
Have you ever danced with the Devil in the pale moon light?
I'm your Huckleberry.
Don't hate the playa, hate the game.
Unreal Tournament 2004 Mexican Mafia «MM»Sternum
Visit AF's Sketching and Drawing Forum.
http://www.automotiveforums.com/vbulletin/f1155/
Old 08-03-2003, 06:43 PM
Wiseguy Wiseguy is offline
its inteferance from your alternator, get better power wires and rca's
Old 08-04-2003, 05:14 PM
Streetwise's Avatar
Streetwise Streetwise is offline
Send a message via Yahoo to Streetwise
Try running your power wires and rca's on opposite sides of the car. Could be a ground loop. Check your ground. It should be at least as big as the power. And keep the ground as short as possible. Sounds like its picking up noise, so check every connection too. Could be bad rca's. Loose connections or product failure.
Old 08-20-2003, 03:57 AM
Dreem Dreem is offline
If you have subs and an amp, you have to get new stronger Wires and Capacitors because the radio is not getting enough electrical power same thing with the engine it is inteferring with each other.
Old 08-20-2003, 06:32 PM
Revolution 7o7 Revolution 7o7 is offline
ur have a bad ground i had this happen in my old car u just need to relocate ur ground wire and more than likely by new rca's if u have anymore ?'s lemme know
05 Camry - Noise accelerating from stop micallen Camry/Camry Hybrid/Vista 4 10-11-2009 09:09 AM
96 Cutlass Supreme w/ humming noise coming from under the back of the car chrisluna Cutlass Series 1 09-28-2009 12:11 PM
annoying humming noise coming from speakers chevy FAn Car Audio 14 01-18-2005 01:51 PM
98 camry air noise coming from right rear speaker moparmick Camry/Camry Hybrid/Vista 0 10-10-2004 09:11 PM
noise from speakers 91civhatch '88 - '91 Civic | CRX | Wagon | Shuttlee 2 12-29-2003 05:28 PM
