Old 01-04-2005, 09:57 PM
chevy FAn chevy FAn is offline
Send a message via AIM to chevy FAn
Angry annoying humming noise coming from speakers
I have a 94 s10 blazer with 2 ten inch Audiobahn subs and 2 6x9's. The 6x9's make a really loud humming noise it gets louder when you accerlate and picks up all kinds of noises from the car. I have tried jsut about everything to fix it, from new grounds, differnt amps, new rca cables, differnt cd player, and differnt speakers nothing has worked can someone please tell me what to do?
Old 01-04-2005, 10:02 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: annoying humming noise coming from speakers
That's called an alternator whine..... try getting a line ouput converter.....also where are your gains on the amp for the humming speakers?
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 01-06-2005, 04:45 PM
my gains are all the way up
Old 01-06-2005, 08:34 PM
That's your problems......gains are made to match input voltage not a volume knob........ go through and match up all your gains RIGHT and you won't have the problem......at least not as bad also if your RCA's and power wire are ran next to each other switch the side on one of them you can pick up some interference that way.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 01-06-2005, 10:48 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
okay, about that... how do you know when you've set the gain to match the input voltage?
Old 01-06-2005, 10:52 PM
Do it by ear if your good by multimeter if you not there's mucho totorials on it hit up jl's site
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 01-06-2005, 10:54 PM
how can you match voltage input by ear?
Old 01-08-2005, 02:11 PM
its not the gains that just makes it louder or less loud but the noise is still there. Someone told me that spark plug wires can cause a noise in the speakers like one i am having does anybody know anything about this?
Old 01-09-2005, 03:41 AM
I know its not the optimal way to solve the problem but theres these things called ground loop isolators... They work. I had a HORRIBLE whine in my speakers just like that, and I bought 1 ground loop isolator and hooked it inline with one of the 2 RCAs going to my 4 channel amp, and it solved the problem forever.
Old 01-09-2005, 10:54 AM
yeah I tried that and taht didnt work
Old 01-09-2005, 02:38 PM
well then your probably just gunna have to deal with it.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 01-12-2005, 07:54 PM
alright not only is the noise coming out of the two 6x9's but a hum out of the subs and the to 5 1/2 inch speakers in the back door but the front ones dont make any hum nosie
Old 01-14-2005, 10:13 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
I had that whine with two Alpine type S 6x9's, and A Power Acoustik amp, I found out the whine was coming from the left channel of the amp...Now I have my Underpowered Xplod and it dosen't do it, same wiring same everything, but different amp (had the amp on my 6x9's for awhile, fried one, don't have a single clue how, they are 220 Watt max but now its powering my Kickers)...Just my Two Cents
Old 01-14-2005, 11:01 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
did you install your RCA's through one side and power wire through the other side
my cardomain
Old 01-18-2005, 01:51 PM
I think i have figured it out its jsut the crappy wiring kits scoshe makes. Two people i know just got subs put in their cars and they both make the humming noise and they have the same wiring kit. I guess you get what you pay for.
